GTK+ 3.0 Scrollbars
Hello all,
I've written a simple Tk/Python program that allows you to adjust the delay before "zoom mode" is activated for scrollbars in GTK+ 3 applications:
https://gitorious.org/gtk-scrollfix/gtk-scrollfix
While it doesn't seem to be possible to disable this feature completely, setting the "activation delay" to a fairly high value (such as 30 seconds) will have much the same effect.
Hopefully the Gnome Tweak Tool will allow you to change this at some point, but perhaps someone will find this useful in the interim.
