main menu on panel
Please change the subject and remove non-relevant parts before answering. My
response below.
2010/9/25 أنس الليثي <name at domain>
> Thnx ivaylo : for your reply
> I have used to do this as you describe in ubuntu but in trisquel I can not
> find the system menu and I do not know how to add it to the panel
> can you kindly tell me from where I can add this menu?
Dear Anas.
You can find the system menu in the main Trisquel menu at the left hand of
the panel that is on the lower part of the screen. It is very easy to add a
separate menu item to the panel as is used in ubuntu by right clicking the
panel and adding "main menu" as a widget.
Saludos/Greetings
Quiliro Ordóñez
Even The Troops Are Waking Up
ACTA – Un acuerdo que puede garantizar la crucificción de
internet
GNU should mean "GNU's not
Ubuntu!
"Lo único que se necesita para que triunfe el mal es que los hombres de bien
no hagan nada." Sergei Bondarchuk
Estas son opiniones personales y no representan la posición de organización
alguna.
