pump.io et Toutatis
Bonjour,
Puisque Identi.ca a fermé l'enregistrement de nouveaux comptes utilisateurs en mars dernier, j'ai essayé d'installer pump.io sur mon toutatis mais je n'y arrive pas et j'ai absolument besoin d'avoir accès à irc.freenode.org pour suivre les évènements du Libre cet été et les activités de divers associations et dans le terminal, j'ai:
:~$ sudo npm install -g pump.io
npm http GET https://registry.npmjs.org/pump.io
npm http 304 https://registry.npmjs.org/pump.io
npm http GET https://registry.npmjs.org/connect
npm http GET https://registry.npmjs.org/connect-auth/0.5.3
npm http GET https://registry.npmjs.org/express
npm http GET https://registry.npmjs.org/utml
npm http GET https://registry.npmjs.org/underscore
npm http GET https://registry.npmjs.org/node-uuid
npm http GET https://registry.npmjs.org/bcrypt
npm http GET https://registry.npmjs.org/dateformat
npm http GET https://registry.npmjs.org/databank
npm http GET https://registry.npmjs.org/step
npm http GET https://registry.npmjs.org/oauth-evanp
npm http GET https://registry.npmjs.org/optimist
npm http GET https://registry.npmjs.org/validator
npm http GET https://registry.npmjs.org/webfinger
npm http GET https://registry.npmjs.org/showdown
npm http GET https://registry.npmjs.org/jankyqueue
npm http GET https://registry.npmjs.org/schlock
npm http GET https://registry.npmjs.org/bunyan
npm http GET https://registry.npmjs.org/emailjs
npm http GET https://registry.npmjs.org/mkdirp
npm http GET https://registry.npmjs.org/connect-databank
npm http GET https://registry.npmjs.org/sockjs
npm http GET https://registry.npmjs.org/dialback-client
npm http 200 https://registry.npmjs.org/connect-auth/0.5.3
npm http GET https://registry.npmjs.org/connect-auth/-/connect-auth-0.5.3.tgz
npm http 200 https://registry.npmjs.org/utml
npm http GET https://registry.npmjs.org/utml/-/utml-0.2.0.tgz
npm http 200 https://registry.npmjs.org/underscore
npm http 200 https://registry.npmjs.org/node-uuid
npm http GET https://registry.npmjs.org/underscore/-/underscore-1.4.4.tgz
npm http GET https://registry.npmjs.org/node-uuid/-/node-uuid-1.3.3.tgz
npm http 200 https://registry.npmjs.org/dateformat
npm http GET https://registry.npmjs.org/dateformat/-/dateformat-1.0.6-1.2.3.tgz
npm http 200 https://registry.npmjs.org/step
npm http GET https://registry.npmjs.org/step/-/step-0.0.5.tgz
npm http GET https://registry.npmjs.org/connect/-/connect-1.9.2.tgz
npm http 200 https://registry.npmjs.org/oauth-evanp
npm http GET https://registry.npmjs.org/oauth-evanp/-/oauth-evanp-0.9.10-evanp.2.tgz
npm http 200 https://registry.npmjs.org/bcrypt
npm http GET https://registry.npmjs.org/bcrypt/-/bcrypt-0.7.6.tgz
npm http 200 https://registry.npmjs.org/express
npm http GET https://registry.npmjs.org/express/-/express-2.5.11.tgz
npm http 200 https://registry.npmjs.org/webfinger
npm ERR! error installing pump.io@0.2.3
npm http 200 https://registry.npmjs.org/databank
npm http 200 https://registry.npmjs.org/optimist
npm ERR! Error: No compatible version found: webfinger@'>=0.3.1- <0.4.0-'
npm ERR! No valid targets found.
npm ERR! Perhaps not compatible with your version of node?
npm ERR! at installTargetsError (/usr/share/npm/lib/cache.js:488:10)
npm ERR! at next_ (/usr/share/npm/lib/cache.js:438:17)
npm ERR! at next (/usr/share/npm/lib/cache.js:415:44)
npm ERR! at /usr/share/npm/lib/cache.js:408:5
npm ERR! at saved (/usr/share/npm/lib/utils/npm-registry-client/get.js:147:7)
npm ERR! at Object.oncomplete (/usr/lib/nodejs/graceful-fs.js:230:7)
npm ERR! You may report this log at:
npm ERR!
npm ERR! or use
npm ERR! reportbug --attach /home/utilisateur/npm-debug.log npm
npm ERR!
npm ERR! System Linux 3.2.0-45-generic
npm ERR! command "node" "/usr/bin/npm" "install" "-g" "pump.io"
npm ERR! cwd /home/utilisateur
npm ERR! node -v v0.6.12
npm ERR! npm -v 1.1.4
npm ERR! message No compatible version found: webfinger@'>=0.3.1- <0.4.0-'
npm ERR! message No valid targets found.
npm ERR! message Perhaps not compatible with your version of node?
npm http 200 https://registry.npmjs.org/jankyqueue
npm http GET https://registry.npmjs.org/databank/-/databank-0.18.2.tgz
npm http GET https://registry.npmjs.org/optimist/-/optimist-0.3.7.tgz
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/utilisateur/npm-debug.log
npm not ok
donc j'ai essayé d'installer la derniere version de nodejs:
:~$ npm version nodejs
npm ERR! No package.json found
npm ERR! Error: ENOENT, no such file or directory '/home/assiette/package.json'
npm ERR!
npm ERR! or use
npm ERR!
npm ERR! command "node" "/usr/bin/npm" "version" "nodejs"
npm ERR! path /home/utilisateur/package.json
npm ERR! code ENOENT
npm ERR! message ENOENT, no such file or directory '/home/utilisateur/package.json'
npm ERR! errno {}
npm ERR!
npm not ok
