Inviato da TheJennings il Lun, 09/01/2014 - 15:23
Cant install - Help
I'm having an issue with installing. I am using a Mac Book.
I have created my USB and everything is installed successfully but when I reset holding down the Alt key I'm only being given the option to select my Mac HD and not the USB.
Could you give me an easy guide on how to fix this?
I downloaded the Trisquel 700MB CD iso image, GNOME desktop, 64 bit.
