Conky disappears when you click on the desktop
The problem is known, but not all solutions seem to work with Trisquel Mini. Here is my solution:
conky.config:
own_window = true,
own_window_transparent = true,
own_window_hints = 'below,undecorated,sticky,skip_taskbar,skip_pager',
Comment to conky.config:
own_window_class and own_window_type obviously do not have to be defined because the default values are used. own_window_hints removes the bars from the window.
autostart:
@conky --pause=5
