How to boot Trisquel 6 in recovery mode (answer)
If anybody is wondering how to boot Trisquel 6 in recovery mode:
1. open a terminal
2. type "sudo su" and hit enter
3. type "nano /etc/default/grub" and hit enter
4. add # to the following line (you can find this line at the bottom of the file)
GRUB_DISABLE_RECOVERY=true
so now it should look like:
#GRUB_DISABLE_RECOVERY=true
exit (press ctrl and x at the same time)
enter the y key when prompted to save
5. type "update-grub" and hit enter
6. reboot
You will now have menu entries to boot in recovery mode.
If any one has time to clean this up and add it to the wiki... feel free.
