2 network cards
Dear Trisquelistos -
I have a question about network issues.
I have a network card in my Thinkpad, which - though it claims to be a
freedom-loving Atheros-card fit for the Ath5k driver - will only work
with a non-free driver. This is a known issue, and... it doesn't seem
likely to change.
Now, I have a PCMCIA card which loves the RT2500 driver, and which is
on the FSF list of fully supported cards. Therefore, that is what I use
with the FaiF distributions, and that works like a charm.
However, it screws up using Network Manager, because NM will attempt to
connect to my network with both cards, switching back and forth,
getting a connection, throwing the connection - et cetera.
So can you tell me: How can I disable one of the network interfaces? Of
course, I could just use something like WICD, but it is nice to have
the integration of NM managing the networking.
Yours,
Morten
__
Morten Juhl-Johansen Zölde-Fejér
http://writtenandread.net * name at domain
Trisquel-users mailing list
name at domain
http://listas.trisquel.info/mailman/listinfo/trisquel-users
2010/3/7 Morten Juhl-Johansen Zölde-Fejér <name at domain>
> likely to change.
Include the module for the integrated wifi with:
*sudo gedit /etc/modprobe.d/blacklist*.conf
and reboot (or sudo rmmod module).
Saludos/Greetings
Quiliro Ordóñez
Estas opiniones son las de un Consejero de FSFLA pero no representan la
posición oficial de FSFLA porque eso implica el consenso para ello en el
Consejo.
http://quiliro.wordpress.com
"¿Sólo cuando el último árbol esté muerto, el último río envenenado y el
último pez atrapado nos daremos cuenta que no se puede comer dinero?"
"Only when the last tree is dead, the last river is poisoned and the last
fish is caught will we realize that money is not edible?"
On Sun, 7 Mar 2010 22:12:40 -0500
Right, straightforward blacklisting is probably the most unintrusive
approach. Thank you for the idea.
Yours,
M
__
name at domain
> approach.
Not really. Disableing it on network manager would be. :-D
Saludos/Greetings
Quiliro Ordóñez
Consejo.
On Mon, 8 Mar 2010 10:30:46 -0500
> > approach.
But it seems to lump my network cards into one. I couldn't find a way
to disable it without disabling wireless in general.
Yours,
M
__
name at domain
2010/3/8 Morten Juhl-Johansen Zölde-Fejér <name at domain>
> > > approach.
Maybe they share the same module. ¿Have you checked?
Saludos/Greetings
Quiliro Ordóñez
Consejo.
On Mon, 8 Mar 2010 10:47:46 -0500
They couldn't, completely different hardware bases.
I will look into it again. Of course, if I change to Wicd, it will only
try to access the network card I call. And that could be good
preparation for the setup for Trisquel mini...
Cheers,
M
__
name at domain
