Adding Trisquel to the [GNU/]Linux distribution chooser
Hi,
I recently came across this which I had tried a few years ago:
http://www.zegeniestudios.net/ldc/index.php?firsttime=true
I think it's a pretty good resource, but Trisquel is missing :)
I write a short note about this using this feedback form:
http://www.zegeniestudios.net/ldc/feedback.php
If anyone can think of questions that could lead to someone being
presented with Trisquel as their choice of distribution, I'd like to
encourage you to use the above form.
I also noticed the use of "Linux" instead of "GNU/Linux", I'll tackle
that some other time.
Cheers,
F.
Fabián Rodríguez
http://fsf.magicfab.ca
It hasn't been updated in over a year.
I took a look at this. Thing is, it's just got the most popular distros on it, and I found that two different test results gave multiple "100%" recommendations, so it's pretty useless. But since it suggests distros that are unethical, I wouldn't refer anyone to it even if it worked well.
I'd say it's best to just ignore this one. Trisquel being listed there wouldn't hurt anything, but it wouldn't help much either.
On the other hand, this has made me interested in such a program that has a good function (suggests only completely free distros) and actually works (by asking better questions and not suggesting multiple distros). I might do that sometime. It could even be a great excuse to learn Javascript.
Now this would be something! :)
