Artificial Intelligence confessions
30 replies [Last post]
amuza
I sometimes use external AI services that do not require registration. I do it through the Tor Browser but they require JS enabled and, in any case, they are SaSS and consume enormous amounts of resources.
So these services have many bad things on freedom and environment but I sometimes use them (I only know two services I can use through Tor Browser without registering). In my case, despite I often have to go through lots of captchas, these services sometimes help me to save lots of time (and resources too) on some specific tasks.
I would like to know about your experiences with these services, if any, and share links, ways to connect, opinions, etc. But not sure if, despite being in the Troll Lounge were offtopic conversations are allowed, discussing about SaSS services could be going too far. If you think that is the case, please let me know, I will happily understand.
I am also considering to locally run some AI software on my own server, but I do not know about the resources it may require to obtain results comparable to those I get from the SaSS services I know. I quickly tried once on my computer, but the computer could not cope and crashed.
You need enough RAM to store the billions of parameters of an LLM. Some models are "distilled" and require less RAM. I installed Alpaca from Flathub:
$ sudo apt install flatpak
$ flatpak remote-add --subset=floss flathub https://flathub.org/repo/flathub.flatpakrepo
$ flatpak install flathub com.jeffser.Alpaca
In Alpaca, I then added DeepseekR1 with 14B parameters and it takes less than 13 GB of RAM.
I asked the LLM something to measure: "What types of recurrence relation can be solved using generating functions?"... and it literally "thought" for tens of minute (I do not have a discrete GPU that would accelerate the computation, because those rely on non-free software)! I had never experienced that before, but the question is truly hard and the answer was OK, despite the use of a distilled model.
Zoma
13GB of ram huh... that is a hell of a lot.
I am glad I don't plan to use AI... that is an insane waste of resources. Although I suppose it might have some purposes. But I would say most of the uses that are ethical are just for fun.
Well, that is relative. The non distilled Deepseek R1 model has 671 billions parameters and you probably need one of the servers with at least 512 GB of RAM behind the link I gave to amuza. On the other extreme, the smallest distilled version of Deepseek R1 has only 1.5 billion parameters. Looking at the list in Alpaca, I discover a related fined-tuned version, called DeepScaleR, with 1.5 billion parameters too: https://pretty-radio-b75.notion.site/DeepScaleR-Surpassing-O1-Preview-with-a-1-5B-Model-by-Scaling-RL-19681902c1468005bed8ca303013a4e2
I am installing it now, to test how faster but worse the answer to the hard question I made yesterday (I did not realize at the time, it would take that much time and I did not clock).
Zoma
Still, I bet this AI functionality requires a fairly powerful computer with a lot of ram.
Processor probably has to be either A:
Something like the TALOS 2 and/or a desktop computer in general.
or B:
It has to be like beyond like an eighth gen processor. I guess my point is, neither gnuboot or canoeboot can use such a functionality.
Although there are libreboot and coreboot devices new enough to do this I suppose.
Even older laptops such as the T400, the T500 or the X200 can have 8GB of RAM, right? That should be enough to use DeepScaleR since, as I wrote, even using it through Alpaca, less than 5GB of RAM is required. The answer time will be longer though, because of the older CPU and the DDR3 RAM. And there are even more distilled models. Qwen3 has a 0.6-billion-parameter version and another one with 1.7 billions. And, yes, their weights are licensed, like Deepseek R1's, licensed under a free software license (the Apache 2 license).
Zoma
Oh, you said 13GB of ram that's why I said that and it sounded like the AI would use a lot of cpu power I thought too.
Nevermind then.
Although I wonder how long it would take on a sandy bridge vs newer stuff though.
Also wonder how much heat it would create too.
I mean it sounds like it uses a lot of resources.
Well, you can try if you have such a machine. I don't.
Quite a lot: all cores are used. During winter in a cold country (unlike mine), it is not a waste though.
amuza
Have you ever asked that to a SaSS AI?
If so, how long did it take to give you a similar answer?
I do not do SaSS. The answer certainly comes much faster because the server is probably one of those: https://en.wikipedia.org/wiki/Nvidia_DGX
With the DeepSclaleR model, running in Alpaca, less than 5 GB of RAM are required (including the RAM to run Alpaca itself) and the same question ("What types of recurrence relation can be solved using generating functions?") is answered in ~6 minutes. The answer is not as good as that of Deepseek R1 with 14 billions parameters. It says that the solvable types "include both linear homogeneous and nonhomogeneous" recurrence relations, which is true because of the choice of verb, "include", but kind of deceptive: it does not mention that some non-linear recurrence relations are solvable in this way, for instance to find a closed-form expression for Catalan numbers, as DeepSeek R1 answers.
I asked DeepSeek R1 the same question again, in a new conversation, to clock the time it takes: ~40 minutes. I repeat: the question is particularly hard (I had never seen such times) and everything runs on a six-year-old CPU (an i7-10510U though).
If you are interested in the answers (and the preceding thoughts, actually written after in the file) of the two models regarding the question, they are attached.
AttachmentSize
DeepScaler-answer.txt 7.84 KB
Deepseek R1-14B-answer.txt 14.19 KB
Zoma
your i7-10510U took 40 minutes?
I wonder how long sandy bridge would take then.
Geshmy
I posited your question to Dickduckgo's ai - Mistral version. Uploaded the answer which came rapidly, maybe 2 seconds. How does it compare?
AttachmentSize
FirstAIQuestionFromMagicBanana.txt 2.75 KB
It is more complete. Executing on GPUs is much faster, but I do not think it is possible using a free firmware and driver.
Phi4 (under the Expat license) takes ~9 minutes to well answer the question.
AttachmentSize
Phi4-answer.txt 2.54 KB
GNUser
I have tried running ollama with my T400 (4GBs of RAM). The models I can run, are either too slow (CPU only) or... dumb.
I suppose with a higher end machine the experience would be more in line with what Magic Banana mentioned, better replies but still running slow (due to CPU only).
I don't use AI often anyways, more for fun experimenting really. IN my workplace it is being heavily implemented though.
I do bring a share of a website though that people might want to use, since it works well with Tor Browser (no captchas!), no registration required, has many free models available, and only minimal JS is required (meaning you only need to allow the main website JS in NoScript, other than that you can use it with the security slider up to Safest, unlike many other websites I checked that give a lot of errors and require third-party JS). It's not perfect but so far the best solution I have found: www.hotbot.com
As for www.duck.ai I don't understand, sometimes it works with the Tor Browser some others it doesn't! Maybe I should ask the AI about it :-P
If anyone has similarly clean websites that would work in these conditions, I would be happy to know about :)
GNUser
Apologies, I correct myself. Just checked the website and you also need to allow "jsdelivr.net" for it to work.
I haven't used it in a while, maybe I misremembered or they just changed it lately.
Still, it's the cleanest experience I have had in AI websites.
Open for suggestions from others :)
Geshmy
I installed Alpaca, then Ollama plugin, then Mistral and asked MagicBanana's question: What types of recurrence relation can be solved using generating functions?
The answer took between 3 and 4 minutes. See attached.
New to me laptop has i5-8250U CPU and 16 Gb RAM.
How did it do. Was my first foray.
AttachmentSize
Recurrence relations that.txt 1.28 KB
Zoma
How much ram did it use?
I have 32GB of ram on my laptop and it also has i5-8250U. :D
Well one of them anyhow, the other has i5-8350U and also 32GB of ram.
I guess I wondered if more ram would make a difference. Not that I plan to do much AI stuff.
It makes a difference in how large the used model can be. How many billions parameters in it. The model should fit into main memory (using swap, everything would be much slower). If it does, then more RAM makes no difference.
Zoma
Interesting, would not have guessed that.
GNUser
Hey everyone,
So, as a possible way to minimize running non-free software on your own machine, I thought this website could be helpful for others.
https://scitely.com/
You create an account (yeah, JS required for that unfortunately, and it feels bloated, be prepared lol), and create free API keys, from that point on you no longer rely on JS web-interfaces or whatever. You can only go with curl, python, etc. Access through Tor is hit-and-miss sometimes the exit node might be in a blacklist and not work. Most of the time it does though.
Not a lot of models in the free tier (if you wish to support their work I think it would be great and you get access to a lot more models, including image/video creation), but still some FLOSS ones are included if you choose to pick those.
As an experiment I even had it cook a small script that creates continuous chats with save/load options included. It worked great, if anyone wants to use it let me know and I will share it.
Again, this is NOT LOCAL, keep that in mind, just a lesser-bad option I guess. Hope it helps anyone :)
computer.user
Proton, a company that offers a suite of privacy-focused services, now has it's own ai service, Lumo. No account required but js is required and you cannot talk with it for very long without an account. So if Proton is freedom-respecting enough for you, Lumo is an option.
I've used it a few times; it gave lots of incorrect or maybe just out-of-date details for one task and it continually outputs way more than I've asked for even after I ask it to stop.
I haven't been very worried about the JS running with these services because I have many things blocked by my proxy and because I have the Abrowser tracking protection turned up to the strictest level.
Unless you download Lumo (maybe from https://github.com/ProtonMail/WebClients/tree/main/applications/lumo maybe) and run it locally, it is SaaSS, "another way to give someone else power over your computing": https://www.gnu.org/philosophy/who-does-that-server-really-serve.html
computer.user
Yes obviously, but OP asked for opinions and experiences related to the topic, not non-SaaS solutions only.
I cannot figure out how to quote on this forum.
Avron
By sending your data to the computer of someone you don't know, you have even less control on how your data are processed than by using non-free software on your own computer. Since we don't "help" people using non-free software on this forum, we should also not "help" using SaaS.
You can use the > character and paste the text to quote, or use italics (<em> pasted text </em>), up to you.
The forum interprets the "cite" tag too: https://trisquel.info/en/filter/tips
Zoma
At first I thought you meant proton as the wine fork made by steamos. Which, I would be interested in knowing if that's as libre as wine.
But, I read some more and realized you meant proton.me the website.
I wonder if this is made with libre code only as well.
Although it is still a case of who does that server serve.
Most of Proton is nonfree:
Copyright (c) 2018-2022, Valve Corporation
All rights reserved.
https://raw.githubusercontent.com/ValveSoftware/Proton/refs/heads/proton_10.0/LICENSE.proton
Zoma
Ah okay, makes sense. Explains how they can support 90% of windows games...
Although, I did see this in license:
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
Seems you can modify the code if you want.
That definitely leaves me with a few questions.
Legimet
I've been reluctant to adopt AI, but I also have been using one of the AI services lately. A few days ago, I asked it some mathematical question (something to do with group algebras and ring/module theory, for those familiar) that I couldn't find the answer to by web searching, and it pointed me in the right direction.
It would be nice to run these models locally, but they will run slowly without GPU, which is typically NVIDIA. Maybe AMD (still requiring proprietary microcode, but much better than NVIDIA) is a viable option?
