Asus A68HM-PLUS review
hi
Asus A68HM-PLUS i wil ask if this motherboard is aplicable for LINUX , there is UEFI BIOS , is possible turn off safe bios , let me know , or say me +/- same motherboard for Linux - Trisqeul ,
Sorry, I had a hard time figuring out what you wanted to say.
If UEFI can be turned off, if the user can inform the UEFI about his
trusted keys or manage exceptions for the complains from the UEFI, then
it's OK, as it's Secure Boot. If the user can't easily turn it off,
can't manage exceptions, or if it doesn't allow the user to insert his
own trusted keys, then it's Restricted Boot, as explained here:
It's important to note that, if I understood your question correctly,
one must understand that most motherboards work with free software right
out of the box. The things that cause most problems are GPU, wifi and
Bluetooth.
Hi.
I know English isn't your first language so I'll give you one chance to rephrase your last post into something that is not insulting and rude --and doesn't get you banned--
