Back to Trisquel 7, need some help
Hi all.
So I am going to give Trisquel another try.
I have some questions before I proceed:
1. I have Debian 7.8 installed with full disk encryption. Is there a way to format the entire partition and install Trisquel without losing the encryption already in place? It took almost 24 hours to get my disk fully encrypted last time, I don't want to go another round like that.
2. Trisquel 7 is based on Ubuntu 14.04 which is in turn based on Debian 8 (which is now the stable version). Since Ubuntu 14.04 is LTS I suppose they will provide backports from times to times. Are those integrated in Trisquel? Or will we have the same software versions in 2016, 2017...?
3. How fast are the security updates coming? I remember that I left Trisquel because of the slow security updates at the time. When I install the DVD, will there be a ton of updates that are necessary?
4. Is it ok to install from a USB instead of a real DVD? I was gonna use unetbootin to put the iso in my USB device and take it from there. Any problem with that?
I hope someone will take the time to answer these, as I feel these are important questions :)
Thanks everyone!
*sorry only know the answer to one of your questions
"Is it ok to install from a USB instead of a real DVD?"
yes its effectively exactly the same
Thanks for your reply tomlukeywood!
I have seen the work you have been doing for freedom, keep up the good work!
Except for the fact that (for me, at least) GRUB never installs correctly when
I install it off USB- either in Debian or Trisquel. It always seems to either
write to the USB itself, or to some non-device, even when I manually
specify /dev/sda. So I always install from USB, but I like to keep a live CD
handy to chroot and install GRUB manually.
1. I am not sure but I think that formatting (i.e., installing a new filesystem) necessary means losing the encryption in place on the older filesystem. Here is the Trisquel documentation pertaining to full-disk encryption: https://trisquel.info/en/wiki/full-disk-encryption-install
2. Besides the Web browser (Abrowser) that is proposed in the latest version, you can enable the backport section of Trisquel's repository: http://packages.trisquel.info/belenos-backports/
3. Security updates usually reach Trisquel's repository a few hours or days after they reach Ubuntu's. There will indeed be a ton of updates to install after installing Trisquel from its ISO. You can choose the NetInstall though. You would then minimize the amount of (unsafe) software you download.
4. You can install from a USB drive: https://trisquel.info/en/wiki/how-create-liveusb (I would simply use 'dd' from your Debian system)
Thanks for your detailed reply!
1. That's what I thought too. Sigh... I will have to lose some time then.
2. So, if I just use the Belenos repository I will get security updates, but no newer versions. For that I need the backports. But where do these backports come from? Ubuntu or Debian? And which branch? I honestly wouldn't like to have stuff from Debian unstable in my PC, but would be ok with the newer debian testing stuff. Maybe I am nitpicking, but I don't want to come here complaining that Trisquel crashes a lot on my machine :P
Btw, how do I add belenos backports?
3. When using netinstall what security is in place? HTTPS? GPG verification? NONE??
4. Thanks! Grown used to unetbootin :P
2. Almost all Trisquel packages come from Ubuntu's respective repositories (e.g., the packages backported to Trisquel 7 are packages backported to Ubuntu 14.04). When I write that they "come from Ubuntu", I mean they were copied and maybe patched to satisfy Trisquel's exigences in term of freedom. Trisquel hosts its own repositories. That includes the "backports". I do not think Trisquel proposes any package directly copied from Debian, especially not from Debian unstable. In my experience, Trisquel never crashes in normal use (I run my home-made programs that sometimes run out of memory, hence the kernel killing processes).
3. You can verify the integrity of the ISO with both 'md5sum' and GPG if that is what you mean. When fetching the packages (during a NetInstall or later, from the installed system), APT check their authentication and, by default, does not install unauthenticated packages.
4. I guess you can use UNetbootin too.
Thanks for the clarifications.
I will maybe try and compile freenetbootin once I get my Trisquel install done :)
In your experience (and other people's too) the Trisquel Belenos repository (without backports) is basicay equal to Debian 8, or does it have newer versions (for stuff like LibreOffice, KODI, GIMP, etc) ??
Is it really required to use the backports to get newer versions of these?
Like I wrote: the versions of the packages in Trisquel 7's repository almost always are those of Ubuntu 14.04.
Jim Fulner
Proudly supporting Free Software
Sent from my Android/Linux device with K-9 Mail. Please excuse my brevity.
On October 13, 2015 11:45:34 PM EDT, name at domain wrote:
>Send Trisquel-users mailing list submissions to
> name at domain
>To subscribe or unsubscribe via the World Wide Web, visit
> http://listas.trisquel.info/mailman/listinfo/trisquel-users
>or, via email, send a message with subject or body 'help' to
> name at domain
>You can reach the person managing the list at
> name at domain
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of Trisquel-users digest..."
>Today's Topics:
> 1. Re: Format for USB memory sticks to be used on GNU/Linux
> (name at domain)
> 2. Re: Flyer Ideas about distributed computing (name at domain)
> 3. Re: My heatsink fan is not working. (name at domain)
> 4. Re: Deleted default panel (name at domain)
> 5. LibertyBSD closure (name at domain)
> 6. Re: What makes a good community (name at domain)
> 7. Re: LibertyBSD closure (name at domain)
> 8. Re: Librebooted Macbook 2,1 (name at domain)
> 9. Re: LibertyBSD closure (name at domain)
> 10. Re: Comments on the attached Creative Commons infographic?
> (name at domain)
> 11. Re: Comments on the attached Creative Commons infographic?
> (name at domain)
> 12. Re: Deleted default panel (name at domain)
> 13. Re: LibertyBSD closure (name at domain)
> 14. DRM may be added to JPEG format in the future
> (name at domain)
>Message: 1
>Date: Wed, 14 Oct 2015 02:48:13 +0200 (CEST)
>From: name at domain
>To: name at domain
>Subject: Re: [Trisquel-users] Format for USB memory sticks to be used
> on GNU/Linux
>Message-ID:
> <name at domain>
>Content-Type: text/plain; charset=UTF-8; format=flowed; delsp=yes
>There is a 4GB file limit. I routinely work with files exceeding this
>amount
>so if I needed compatibility with Windows (I don't - this is a thought
>experiment), FAT would cause problems then.
>Message: 2
>Date: Wed, 14 Oct 2015 02:48:19 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] Flyer Ideas about distributed computing
>Message-ID:
> <name at domain>
>Here is the newest version.
>Message: 3
>Date: Wed, 14 Oct 2015 02:53:09 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] My heatsink fan is not working.
>Message-ID:
> <name at domain>
>"When I turn the laptop on the fan doesn't start up I thought it is
>suppose
>to start when you first start the laptop up."
>Not necessarily. Some computers will vary fan speed from all the way
>off to
>all the way maxed out based on the reported temperatures of various
>sensors
>(you can even read these temperature sensors from within GNU/Linux) in
>an
>attempt to control the amount of power used and noise level.
>Message: 4
>Date: Wed, 14 Oct 2015 02:55:55 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] Deleted default panel
>Message-ID:
> <name at domain>
>What happens if it doesn't? What would I lose?
>Message: 5
>Date: Wed, 14 Oct 2015 02:59:06 +0200 (CEST)
>To: name at domain
>Subject: [Trisquel-users] LibertyBSD closure
>Message-ID:
> <name at domain>
>I won't be able to continue LibertyBSD any more, and I'm extremely
>disappointed about this. The problem is, my ISP suddenly, without
>warning,
>blocked port 80 and port 443. For several months, I believed that this
>was a
>problem with my router or modem and tried everything to fix it. But
>eventually, I realised that the problem wasn't on my end. (This was
>also bad,
>because my Ubiquiti GPL violation page had also gone down.)
>I'm 17 years old and I live with my parents, so I can't exactly change
>ISPs
>or get a business account. I've tried finding free hosting, but not
>successfully.
>If there's anything that you need help with, or if you want to continue
>the
>project yourself, I'll try to provide assistance where I can (e.g.
>diffs,
>domain name).
>I'm really sorry for any inconvenience which this may have caused you
>all. I
>want there to be a libre BSD as well, but at the moment, it's just not
>possible for me to do.
>AllBSD has a complete mirror of the files which is still up which you
>might
>find useful:
>ftp://ftp.allbsd.org/pub/LibertyBSD/5.6/
>Message: 6
>Date: Wed, 14 Oct 2015 03:13:04 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] What makes a good community
>Message-ID:
> <name at domain>
>Many points are important and should be a good goal. But some are, to
>be
>honest just strange...
>I my self was bullied in school, later got to a inclusive school (for
>disabilities and non-disabilities). I know many points, and know how
>important they can be (Up to Level2).
>The Constantly important things in my opinions are:
>Repeat harassers are removed from conferences and banned from
>communication
>channels (At least until they better them self)
>Newbies are warned about any ?missing stairs? and people who give
>unhelpful feedback (I think no newbie has to get misinformed)
>The whole community, including leadership and community managers
>actively
>enforce communication standards
>Documentation on where to interact with the community (irc, mailing
>list, bug
>tracker, etc)
>Documented first steps for compiling, running, testing, and polishing
>contributions
>Step-by-step tutorials, which are kept up-to-date
>How to give back non-code contributions (bug reports, docs, tutorials,
>testing, event planning, graphical design)
>Newbie todo lists
>Community creates a casual feedback channel for generating ideas with
>newcomers (irc, mailing list, slack, whatever works)
>Community members write tutorials on the art of patch review, release
>management, and the social side of software development
>Constantly improves documentation
>Conferences include child care, clearly labeled veggie and non-veggie
>foods,
>and a clear event policy (Yes I know that childcare can be difficult
>but it
>could help)
>Community participates in diversity programs (So we can lern from the
>"others")
>Message: 7
>Date: Wed, 14 Oct 2015 03:18:04 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] LibertyBSD closure
>Message-ID:
> <name at domain>
>hi orthogonal
>no its will not end
>we will try help you
>you can use
>unixssh.com hoste
> its free
>and for free domain you can use tk
>Message: 8
>Date: Wed, 14 Oct 2015 03:27:09 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] Librebooted Macbook 2,1
>Message-ID:
> <name at domain>
>pizzaiolo: I got an idea: insert the USB stick when you are in GRUB.
>This way
>you should be able to use USB installers for GNU/Linux.
>Message: 9
>Date: Wed, 14 Oct 2015 03:55:22 +0200 (CEST)
>To: name at domain
>Message-ID:
> <name at domain>
>I could host the site for you-- given that you don't mind using SSH or
>FTP to
>connect to the server.
>Message: 10
>Date: Wed, 14 Oct 2015 04:16:22 +0200 (CEST)
>To: name at domain
>Subject: Re: [Trisquel-users] Comments on the attached Creative
>Message-ID:
> <name at domain>
>"It's very rare for litigation to be necessary to enforce copyleft
>licenses.
>All that's usually necessary is politely (and privately) explaining to
>the
>infringer about the violation and how to correct it."
>Indeed. Conservancy recently published some key principles and that's
>in
>there:
>https://sfconservancy.org/linux-compliance/principles.html
>Message: 11
>Date: Wed, 14 Oct 2015 04:19:49 +0200 (CEST)
>To: name at domain
>Message-ID:
> <name at domain>
>"How do the artists and coders among you deal with this issue?"
>The license (or not) selected serves as a constitution, and strong
>copyleft
>reflects my own beliefs and values.
>Message: 12
>Date: Wed, 14 Oct 2015 04:35:30 +0200 (CEST)
>To: name at domain
>Message-ID:
> <name at domain>
>I went ahead and did the delete of .config and after reboot everything
>was
>back. Thanks!!
>Message: 13
>Date: Wed, 14 Oct 2015 05:42:30 +0200 (CEST)
>To: name at domain
>Message-ID:
> <name at domain>
>Thank you so much! I'd really appreciate that. My email is
>name at domain, and if you'd like to encrypt the login details
>for
>security, my key is 968A8DEE and can be found at pgp.surfnet.nl.
>Message: 14
>Date: Wed, 14 Oct 2015 05:45:33 +0200 (CEST)
>To: name at domain
>Subject: [Trisquel-users] DRM may be added to JPEG format in the
> future
>Message-ID:
> <name at domain>
>http://news.slashdot.org/story/15/10/13/2338211/drm-in-jpegs
>Kinda scary if this actually happens.
>_______________________________________________
>name at domain
>End of Trisquel-users Digest, Vol 76, Issue 77
