Can't grow ext4 partition with GParted running from USB
I have been using GParted to try to resize the primary root partition (ext4) on Bishop (my 32-bit laptop), increasing it by about 2GB into free space to the right of it (as visualized by GParted). I've tried it with a Flidas live USB and with a Flidas system I installed to a USB. In both cases it failed.
Here is the full error message from GParted (from the installed system):
> begins
GParted 0.25.0 --enable-libparted-dmraid --enable-online-resize
Libparted 3.2
Grow /dev/sda1 from 13.97 GiB to 15.88 GiB 00:00:00 ( ERROR )
calibrate /dev/sda1 00:00:00 ( SUCCESS )
path: /dev/sda1 (partition)
start: 2048
end: 29296639
size: 29294592 (13.97 GiB)
check file system on /dev/sda1 for errors and (if possible) fix them 00:00:00 ( ERROR )
e2fsck -f -y -v -C 0 /dev/sda1 00:00:00 ( ERROR )
e2fsck 1.42.13 (17-May-2015)
/dev/sda1 has unsupported feature(s): metadata_csum
e2fsck: Get a newer version of e2fsck!
> ends
Any suggestions?
I guess the system that made the filesystem had a newer version of Linux (which includes the code for the filesystems) than Trisquel 8. Try from a live GNU/Linux system that is more recent (unfortunately, that cannot be Trisquel, until an ISO for Trisquel 9 is released).
You have here a guide to remove unsupported feature (metadata_csum) from
a mounted partition, booting from affected OS:
https://wiki.openvz.org/Installation_on_Debian_9
After this, you'll can use Trisquel 8 for desired actions over this
modern Ext4 partition.
El 13/5/19 a les 13:25, name at domain ha escrit:
>> begins
> Libparted 3.2
> start: 2048
> end: 29296639
> 00:00:00 ( ERROR )
>> ends
> Any suggestions?
As suggested by the output: You need a newer version of e2fsck.
If you were using a Live media of Trisquel, try to download its deb package from Debian's main (libre) repository, either testing or unstable, and then use # dpkg -i to install it. Hopefully you don't need to update its dependencies first.
Unfortunately, most popular specialist distributions such as GParted Live and Parted Magic have non-free firmware, so I don't encourage you to use them, unless you could find a deblobbed (liberated) version.
Magic Banana:
Nope. The system that made the filesystem was either a Trisquel 8 boot USB, or maybe even a Trisquel 7 one.
I suppose this is as good a reason as any to do a test run of the newly released Trisquel 9 beta ;)
Narcis Garcia:
a mounted partition
Thanks for the link, but what is "metadata_csum" and if I remove it, what are the potential consequences for my ext4 file system?
nadebula.1984:
I've tried it from an installed system I installed to a USB instead of hard drive as an experiment. I ran apt-get update and apt-get dist-upgrade on it and made sure it was fully up-to-date before I tried resizing with GParted.
So a) if a newer version of e2fsck is required it's not yet in the Trisquel 8 repos and b) why would such a new version be required to resize a partition made with a Trisquel 8 boot USB? It seems like there is something else going on here and that output is just guessing.
El 15/5/19 a les 9:04, name at domain ha escrit:
> Narcis Garcia:
> a mounted partition
"metadata_csum" is a new Ext4 feature (optional but enabled by default
when formatting in Ext4) to record a checksum for inodes metadata.
Consequence of metadata_csum removal is only to not be used: same as all
previous Ext4 volumes.
If you format in Ext4 with Trisquel 8, you will not have metadata_csum.
Procedure I linked is to be able to solve your problem without
installing/uninstalling/upgrading any software: Just with stuff and
situation you already have.
Narcis Garcia:
But format in Ext4 with Trisquel 8 (or 7) is exactly what I did! Is it possible this was added somehow when I deleted the swap partition or created the swap file on that partition? How can I test whether there is a metadata_csum on an ext4 partition?
I believe the following command (where /dev/sda1 may have to be changed: it must be the partition you want to resize) would tell, among "Filesystem features":
$ sudo tune2fs -l /dev/sda1
'tune2s' should also allow you to remove the metadata_csum feature:
$ sudo tune2fs -O ^metadata_csum /dev/sda1
Source: https://ext4.wiki.kernel.org/index.php/Ext4_Metadata_Checksums
El 16/5/19 a les 18:20, name at domain ha escrit:
> Narcis Garcia:
If Trisquel 8 does not support completely the extra metadata_csum
feature, I'm really curious why you didn't disable it yet.
It seems to be the only way to proceed with 100% Libre software or
without unsinstalling/installing anything else.
(I assume that Ext4 partition has OS boot)
Don't forget that Trisquel 8 is based on Ubuntu 16.04 so its packages are, to some extent, outdated. Whereas many improvements to the e2fsck can have happened within the recent 3 years.
By contrast, the GParted Live is built on Debian sid (unstable) so it's packages are very new. However, it comes with no shortage of non-free firmware and has Debian's non-free repository enabled by default. This is why I don't encourage you to use it. But you can just try to "customize" your own free/libre specialist distribution installation for disk management. A good starting point can be the official (blob-less) Debian Installer (testing). First, install a minimal copy to a portable storage media, and then optionally add components by running "tasksel" (as root) after customizing the apt repositories (I routinely use "sid", or unstable). Avoid adding "contrib" or "non-free" and you'll have a free/libre installation which is always up to date.
