certifcate error updating fresh install of both Triskel 11 and Trisquel 11
6 replies [Last post]
DdddRrrt
Hi All,
noticed this the last few days for both full installation and using a virtual environment in Gnome Boxes.
'Failed to fetch https://mirror.operationtulip.com/trisquel/packages/dists/aramo-security/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)The repository 'https://mirror.operationtulip.com/trisquel/packages aramo-security InRelease' is not signed.Updating from such a repository can't be done securely, and is therefore disabled by default.See apt-secure(8) manpage for repository creation and user configuration details.Failed to fetch https://mirror.operationtulip.com/trisquel/packages/dists/aramo-updates/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)The repository 'https://mirror.operationtulip.com/trisquel/packages aramo-updates InRelease' is not signed.'
Any ideas what 'https://mirror.operationtulip.com/trisquel/packages/dists/aramo-security/InRelease' is supposed to be?
Thanks!
Regards
jxself
If you go to the operationtulip.com domain name it appears that it's no longer in service. It seems appropriate at this point to use a different mirror.
DdddRrrt
Thanks JXself!
Apologies - I had not seen that repository previously and don't remember configuring it so thought it was odd that it was there at all.
Regards
Saymon00
Hey man did you find out where can I find the new mirrors?
del111
Here: https://trisquel.info/en/wiki/mirrors
I had to use the search function. I couldn't find it on the site.
xerxespersrex
Hello, I just started using Trisquel last week and I had the same issues myself when I installed. I eventually landed on the FSF's mirror and it's been working fine for me so far, the system updates and everything's good. This is what's in my /etc/apt/sources.list file:
deb https://mirror.fsf.org/trisquel/ aramo main
deb-src https://mirror.fsf.org/trisquel/ aramo main
deb https://mirror.fsf.org/trisquel/ aramo-security main
deb-src https://mirror.fsf.org/trisquel/ aramo-security main
deb https://mirror.fsf.org/trisquel/ aramo-updates main
deb-src https://mirror.fsf.org/trisquel/ aramo-updates main
I also enabled the backports repository:
deb https://mirror.fsf.org/trisquel/ aramo-backports main
deb-src https://mirror.fsf.org/trisquel/ aramo-backports main
But it only pulled in a few extra packages, so I don't think it's worth it for the potential instability.
Saymon00
Thank you guys for help me :)
