Compile Trisquel 6 console installation from source code
Greetings,
I'd like to compile the Trisquel 6 console installation from source code. My search for how this can be done yielded no results. I suspect that I will need to know:
1. What source code is installed as part of the console installation
2. Where I can find this source code
3. How to create a local mirror of this source code
4. How to compile this source code
Can someone shed some light on the above?
The repositories hosts not only pre-compiled packages but their sources too (deb-src). You just need to enable those repositories (from /etc/apt/sources.list). The NetInstall is, I believe, the metapackages trisquel-base and trisquel-base-recommended (and, obviously, their dependences).
