Computers which work well Trisquell.
Hi!
At the moment I have a Dell computer.
But it doesn't work well with Trisquel because of the drivers
Any laptop 15" as a recomendation?
Thanks for help!
The best for your freedom is a RYF laptop: https://ryf.fsf.org/categories/laptops
If you need newer hardware, you will not have a 100% free BIOS and should choose any computer with an Intel graphical chipsets. Almost certainly, you will also have to acquire a Wi-Fi dongle. You can go for https://ryf.fsf.org/categories/wireless-adapters or search "AR9271" on a site such as ebay (that would be cheaper, but you would not support vendors dedicated to respecting your freedom).
Some good FSF approved laptops can be found at Technoethical and Thonk Peasant:
https://store.thonkpeasant.xyz/index.php?route=product/product&language=en-gb&product_id=50
https://tehnoetic.com/laptops/tet-t500
Aside from RYF laptops some other good 15" options would be from NovaCustom which use the Dasharo version of Coreboot:
https://configurelaptop.eu/ns51-series/
If you can make 14" work instead of 15" then Mini Free; Purism and Vikings have options as well:
https://minifree.org/product/libreboot-t440p/
https://store.vikings.net/en/t440p-laptop-ips-display-i7-4700
If you want to order from Technoethical, at the very least, get a response from them before sending money. I never got my last order delivered, neither did I get any reply.
Vikings and Minifree are reliable.
