Dell Wireless
How do I install the wireless on my Dell laptop? I don't want to use proprietary or non-free software. Are there options available or am I stuck using Ethernet?
Can we have the output of:
lspci -nnk | grep Wireless
Let's see if your wireless WIFI adapter does indeed require proprietary firmware. If so, you will need to either switch it for another (internal) adapter that doesn't require the nasty nasty blob or buy an external USB wifi dongle.
But first the first - the output as mentioned above.
cheers
Firstly, please tell us some specifics. What model of laptop is this?
Secondly, please post the output of the command 'lspci -vmmnn', so we
may have a look at your actual hardware.
That out of the way, the best thing to do if your wifi card really
requires proprietary firmware is to buy one of these:
https://www.thinkpenguin.com/gnu-linux/penguin-wireless-n-usb-adapter-gnu-linux-tpe-n150usb.
dongle.
cheers
