differences from 6 to 7
I'm sure its on the site somewhere but can't find it. Whats different between 6 and 7?
Trisquel 7 has newer software that Trisquel 6, and will be supported longer (Trisquel 6 is supported until 2017, Trisquel 7 until 2019). That's all.
Other noticeable differences are just an indirect result of using newer versions of specific programs.
Trisquel 7 is based on Ubuntu 14.04 while Trisquel 6 is based on Ubuntu 12.04.
The biggest difference between the two that is noticeable, as with most versions of most distros, is how new/old the packages in the repositories are.
