Disturbance at the microphone
A week ago everithing was good with my microphone (internal in the laptop), but today it make one shshshshhshs on the background of the recording...
I tried changing the audio settings and also in alsamixer, but nothing at all...
You could try lowering volumes to zero and muting outputs you don't need,
they sometimes "bleed" into the input causing static. Also, you could try to
see if it's less noisy on battery or plugged in. I guess any peripherals
could also cause it and even built in bluetooth or wifi. Remember to
sacrifice a goat...
Good luck!
open alsamixer and try reducing mic boost :)
You could try lowering volumes to zero and muting outputs you don't need, they sometimes "bleed" into the input causing static. Also, you could try to see if it's less noisy on battery or plugged in. I guess any peripherals could also cause it and even built in bluetooth or wifi. Remember to sacrifice a goat...
Good luck!
The disturbance now is slower, but I've tried all your tips and nothing has changed...
changed...
I've tried but nothing....
