gem & wget not able to resolve
Hi all,
I am facing a weird problem. gem & wget are not able to resolve addresses. while, apt, ping, web browsers work fine.
sudo gem update --system
ERROR: While executing gem ... (Gem::RemoteFetcher::FetchError)
Errno::ETIMEDOUT: Connection timed out - connect(2) (http://rubygems.org/latest_specs.4.8.gz)
wget http://rubyforge.org/frs/download.php/76073/rubygems-1.8.24.tgz
--2012-05-31 11:13:23-- http://rubyforge.org/frs/download.php/76073/rubygems-1.8.24.tgz
Resolving rubyforge.org... 1.0.0.0
Connecting to rubyforge.org|1.0.0.0|:80... ^C
ping rubyforge.com
PING rubyforge.com (50.56.192.79) 56(84) bytes of data.
64 bytes from rubyforge.com (50.56.192.79): icmp_req=1 ttl=44 time=292 ms
64 bytes from rubyforge.com (50.56.192.79): icmp_req=2 ttl=44 time=292 ms
^C
$ cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 192.168.1.1
'export HTTP_PROXY' does not return anything.
I think if the dns resolving for gem & wget gets solved, then gem can use the sources to do automatic installations of gems.
I tried changing nameserver to 8.8.8.8 but after reboot, it reverts back to above.
Please help me resolve this. I tried to manually install gems. But, it is insane task to keep searching & downloading each gem dependency and installing it.
