graphics mode while booting
how can i change the graphics mode for the boot process?
am using the libre-linux kernel from jxself's repository and it used to show me a penguin mascot while booting. at some point the graphics mode must have changed, i can't say when that was, but now i see some garbage pixels during boot. later it changes to the correct graphics mode showing the boot messages and login correctly.
Any idea on how it can show the Freedo mascot again?
Have you changed the reso in grub config? Remember to update-grub afterwards if you do.
Try https://wiki.archlinux.org/index.php/Grub#Visual_Configuration .
Shortly:
$ sudo hwinfo --framebuffer
and set the desired resolution in /etc/default/grub , "GRUB_GFXMODE".
P.S.: And update-grub, of course.
thanks for the help!
somehow grub seems to ignore GRUB_GFXMODE.
building and installing grub-2.00 from source [1] it shows the mascot out-of-the-box
You are welcome :-)
My grub doesn's ignore it. Perhaps the version in Trisquel repos is not ready for your videoboard?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 2013-04-14 15:01, name at domain wrote:
> You are welcome :-)
Don't forget to:
sudo update-grub
F.
Fabián Rodríguez
http://trisquel.magicfab.ca
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: PGP/Mime available upon request
Comment: Using GnuPG with undefined - http://www.enigmail.net/
iEYEARECAAYFAlFsDLUACgkQfUcTXFrypNUFXwCg4zTrngKK/BmMMBPcGG85wxgl
9MEAoL17+JDzaJxAgXflZ/dUqFrdATJs
=w2wG
-----END PGP SIGNATURE-----
