Heat on MacBook 2.1 (librebooted and trisquelised)
8 replies [Last post]
GNUbahn
Running the sensors command (ls-sensors package) gave me this output:
Adapter: ISA adapter
Exhaust : 1798 RPM (min = 1800 RPM, max = 6200 RPM)
TB0T: +23.0°C
TC0D: +57.2°C
TC0P: +53.0°C
TM0P: +47.0°C
TN0P: +49.2°C
TN1P: +50.2°C
TTF0: +60.0°C
Th0H: +54.5°C
Th0S: +54.0°C
Th1H: +53.8°C
coretemp-isa-0000
Core 0: +58.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +60.0°C (high = +100.0°C, crit = +100.0°C)
Can anyone tell me, if that is good or bad?
Time4Tea
Hi! I just liberated my Macbook (2,1) a couple of days ago and that looks perfectly fine to me. I find that when I've got a few applications running the core temps get up to around 70C, but the fan speed increases and brings it down again quickly. It's not too loud, even when the fan is on full.
Btw, I updated the Macbook Wiki page with some info on how to make the touchpad behave better :)
GNUbahn
I just added a few lines about how to reconfigure the keyboard to be able to type e.g. '@'
Time4Tea
Interesting - I haven't encountered any issues with the keyboard. On mine, @ is simply 'shift+2' and the 'US-macintosh' keyboard configuration seems to have everything right (as far as I can tell).
GNUbahn
Hmm, I can't even recall the option to choose DK-macintosh, but next time I trisquelise a MacBook I will look for that option.
IrishUSA
Is there a Dvorak version of the Apple keyboard in Libreboot and Trisquel?
GNUbahn
The possible keyboards of libreboot are easily discovered: Download a zipfile containing the roms specific to your comnputer at: https://www.mirrorservice.org/sites/libreboot.org/release/stable/20160907/rom/grub/
Unzip it and see the possible roms - the name reveals if it is qwerty, dvorak etc
vita_cell
Usually Macbooks are too hot, so 50-60 celcius are normal for that one. Also if you try to see HD or FullHD videos, temperature can raise to 70-75 celcius with 6000rpm, and a lot of loudness.
GNUbahn
So far I'll leave it as is, but I saw that a new fan is about 14$. I might invest in one ocassionally...
