Help! No internet after update
Hello,
Since I installed updates for XML a few days ago, my cable connection stopped working on the next session. It's not the cable or the network device, because I am typing this on the same machine in windows. I also installed some update earlier, one called 'ifupdown' and another network-related update (I guess everyone got those?). I'm running Awen, although since I installed it, my computer seems to have subtle problems here and there.
Does anyone know what can be the problem with my internet-connection?
Thanks in advance!
Regards
On Sun, Sep 12, 2010 at 12:35 PM, <name at domain> wrote:
> Hello,
> here and there.
> Thanks in advance!
> Regards
Have you installed a new kernel release?
What's the output of lspci -nnk on your machine.
Luis A. Guzmán García
My connection works again, but I want to know if something is wrong, so here is the output anyway. Awen is recently also complaining about my battery malfunction because it's critically low (it shows 48%).Thanks!00:00.0 Host bridge [0600]: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub [8086:27a0] (rev 03)
Kernel modules: intel-agp
00:01.0 PCI bridge [0604]: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express PCI Express Root Port [8086:27a1] (rev 03)
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:1b.0 Audio device [0403]: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller [8086:27d8] (rev 02)
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 [8086:27d0] (rev 02)
00:1c.3 PCI bridge [0604]: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 [8086:27d6] (rev 02)
00:1d.0 USB Controller [0c03]: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 [8086:27c8] (rev 02)
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller [0c03]: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 [8086:27c9] (rev 02)
00:1d.2 USB Controller [0c03]: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 [8086:27ca] (rev 02)
00:1d.3 USB Controller [0c03]: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 [8086:27cb] (rev 02)
00:1d.7 USB Controller [0c03]: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller [8086:27cc] (rev 02)
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 Mobile PCI Bridge [8086:2448] (rev e2)
00:1f.0 ISA bridge [0601]: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge [8086:27b9] (rev 02)
Kernel modules: iTCO_wdt, intel-rng
00:1f.2 IDE interface [0101]: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller [8086:27c4] (rev 02)
Kernel driver in use: ata_piix
01:00.0 VGA compatible controller [0300]: ATI Technologies Inc RV515 [Radeon Mobility X1450] [1002:7186]
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 01)
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection [8086:4222] (rev 02)
Kernel driver in use: iwl3945
Kernel modules: iwl3945
04:01.0 CardBus bridge [0607]: Ricoh Co Ltd RL5c476 II [1180:0476] (rev b3)
Kernel driver in use: yenta_cardbus
Kernel modules: yenta_socket
04:01.1 FireWire (IEEE 1394) [0c00]: Ricoh Co Ltd R5C552 IEEE 1394 Controller [1180:0552] (rev 08)
Kernel driver in use: ohci1394
Kernel modules: firewire-ohci, ohci1394
04:01.2 SD Host controller [0805]: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter [1180:0822] (rev 17)
Kernel driver in use: sdhci-pci
Kernel modules: sdhci-pci
04:01.3 System peripheral [0880]: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter [1180:0592] (rev 08)
If it is a removed hardware driver, you should get your connection back by
booting with the previos kernel at startup.
Saludos/Greetings
Quiliro Ordóñez
Even The Troops Are Waking Up
ACTA – Un acuerdo que puede garantizar la crucificción de
internet
GNU should mean "GNU's not
Ubuntu!
"Lo único que se necesita para que triunfe el mal es que los hombres de bien
no hagan nada." Sergei Bondarchuk
Estas son opiniones personales y no representan la posición de organización
alguna.
