High level of hardening in Lynis.
3 replies [Last post]
Qwerty
Hi everyone! I'm trying to raise the Hardening Index in Lynis to the maximum possible. But I want to do it in a way that keeps the system running smoothly.
I've reached a Hardening Index of 81, but I'm stuck there. I'm curious if anyone has managed to get it above 85. I'm really curious and would like to know if anyone has achieved this (while keeping the system fully functional and efficient)
AttachmentSize
Hardening_81.png69.28 KB
Qwerty
I finally managed to increase the hardening to 82, and I think that's the limit if you want the system to remain functional and stable. Beyond that, it's easy to break the system.
I'm writing to advise against touching PAM, pam_faillock, or pam_tally2. That breaks SUDO in Trisquel. It's happened to me! It's best NOT TO TOUCH PAM.
Qwerty
I am writing again because I finally found a solution to SUGGESTION [AUTH-9262] PAM
Maybe this can help someone. Do not try to fix the suggestion with "pam_cracklib" and "pam_passwdqc" pam_faillock, or pam_tally2
I broke the system. AVOID THEM AT ALL COSTS.
I solved it with "libpam-pwquality" this one works well with Trisquel 11.
Thanks to this, the Hardening index in Lynis has risen to 83.
I just finished raising the Hardening to 84
Qwerty
I finally got a Hardening Index of 92 on Lynis. Well, actually, I got 91, because I had to backtrack and disable #kernel.modules_disabled = 1 in /etc/sysctl.d/99-hardening.conf
The reason is that "kernel.modules_disabled = 1" causes USB devices to malfunction and many other problems in Trisquel 11.0.1.
To get to 91 I made mistakes that made me format twice. :)
Trying to go beyond 91 makes it easy to break the system.
Regards.
