How to improve my question?
How to test from Debian GNU/Linux using g++?
I trying compile an example of a book.
The program use three classes: Book, Customer and Library.
When i compile the example with the following command:
g++ -g -Wall Book.cpp book.h -o book
The result expected is bad:
Book.cpp:1:10: fatal error: Set: No existe el fichero o el directorio
#include
compilation terminated.
This example was tested from another compiler. The library is not recognized.
The book is C++17 By Example, published by Packt.
My question was closed!
| Attachment | Size |
| Captura de pantalla_2021-07-30_11-27-12.png | 27.45 KB |
Can you attach/link to the source code you try to compile?
Attach the source code here!
| Attachment | Size |
| source.tar.gz | 1.84 KB |
At first, I imagined that the differences were due to the authors using Microsoft Visual C++ that would be more permissive (I actually have no idea): it would somehow automatically "#include <string>", "#include <list>", #include <fstream> and be "using namespace std;" at the beginning of book.h, add a semicolon at its end, etc. However, there are also typos such as "book" instead of bool" in customer.h, supernumerary quotes at the beginning of the output stream operator for a Book and that operator uses class variables (m_borrowed, m_reservationList and m_customerId) that are not declared.
I would stay away from that content (unless you are responsible for introducing the typos, for mixing different version of files, etc.).
But, how to improve my question?.
You have not linked to the question you asked. Anyway, you should properly describe the steps you followed (without digressions) and precede the commands with "LC_ALL=C " (without the quotes) to have them output messages in English.
