how much of the source code is disclosed about the firefly rk3399 computer?
Can you tell how much of the devices' source code is disclosed?
https://www.kickstarter.com/projects/1771382379/firefly-rk3399-six-core-64-bit-high-performance-pl/description
lkcl says, he can use the rk3399 if he could get hand on the data sheet of the rk3399.
What is the performance of the rk3399, equals a x86 2gzh duo core computer?
I am wondering how free this thing is as well, if the low level components are free and if it runs a free distro I might've found myself a replacement for my PC.
I asked lkcl on arm netbook. He said, the mali gpu source code is not available. About the rest of devices the source code is available. Lkcl said, reverse engineering the mail gpu would be about 150000eu.
Is that Euros? Isn't mali gpu also present in the EOMA68? https://www.crowdsupply.com/eoma68/micro-desktop
Yes but, last time I checked for updates in the EOMA68 page (which was
around 6 months ago, so I don't know if there is improvement on this
Mali GPU issue), I was informed that, while the GPU is physically there
in EOMA68, it won't appear even for the operating system to use it in
the case of Libre Tea Computer Card (in this message, I'll refer to it
as "LTCC" for short), so things will be done by CPU instead. However,
this doesn't apply to all EOMA68. Also, only LTCC is the one seeking
RYF-certification, not EOMA68 entirely, so I can only recommend LTCC,
and ask you kindly to ignore the rest. :)
- [[https://libreplanet.org/wiki/User:Adfeno]]
gratis).
- "WhatsApp"? Ele não é livre, por isso não uso. Iguais a ele prefiro
GNU Ring, ou Tox. Quer outras formas de contato? Adicione o vCard
que está no endereço acima aos teus contatos.
- Pretende me enviar arquivos .doc, .ppt, .cdr, ou .mp3? OK, eu
aceito, mas não repasso. Entrego apenas em formatos favoráveis ao
/software/ livre. Favor entrar em contato em caso de dúvida.
we looked into this in libreboot. paulk and i decided that this system was not worth bothering with (referring to firefly)
