Submitted by TralfamadorianOrator on Sat, 09/01/2012 - 22:59
HOWTO: Build GIMP 2.8 in Dagda (5.0)
With help from some GIMP devs (Martin Nordholds and Mikael Magnusson), after several weeks of trial and error, I've finally gotten the hang of building GIMP 2.8 in Trisquel 5.0.
- Install the build dependencies.
sudo apt-get install fontconfig gtk-doc-tools intltool libcairo2 libdbus-glib-1-2 libexif-dev libfontconfig1 libfreetype6 libgdk-pixbuf2.0-0 libgtk-3-0 libjasper-dev libjpeg62-dev liblcms1-dev liblcms-dev libmng-dev libopenexr-dev libpango1.0-0 libpng-dev libpoppler-dev librsvg2-common librsvg2-dev libtiff4-dev libtiff-tools libtool libwebkit-dev libwmf-dev pkg-config python-dev python-gtk2-dev ruby libgirepository1.0-dev gobject-introspection libpoppler-glib-dev libgfs-1-dev libcroco3-dev git
- Set up the directory for GIMP to be installed in (in this example, I use
/opt/gimp).
sudo mkdir -p /opt/gimp/share/aclocal
- Create the file
/opt/gimp/share/config.sitewith the following contents (for setting up build-environment variables).
export PATH="$PREFIX/bin:$PATH" export PKG_CONFIG_PATH="$PREFIX/lib/pkgconfig:$PKG_CONFIG_PATH" export LD_LIBRARY_PATH="$PREFIX/lib:$LD_LIBRARY_PATH" export ACLOCAL_FLAGS="-I $PREFIX/share/aclocal $ACLOCAL_FLAGS" export XDG_DATA_DIRS="$PREFIX/share:$XDG_DATA_DIRS"
- Set up the build-environment variables.
export PREFIX=/opt/gimp source /opt/gimp/share/config.site
- Clone glib from git, checkout the glib-2-32 branch, build it, and install it.
git clone git://git.gnome.org/glib cd glib git checkout glib-2-32 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone atk from git, leave it on the master branch (at the time that I write this, the master branch is version 2.5.4), build it, and install it.
git clone git://git.gnome.org/atk cd atk ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone pixbuf from git, checkout the gtk-pixbuf-2-24 branch, build it, and install it.
git clone git://git.gnome.org/gdk-pixbuf cd gdk-pixbuf git checkout gtk-pixbuf-2-24 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone pixman from git, checkout the 0.24 branch, build it, and install it.
git clone git://anongit.freedesktop.org/pixman cd pixman git checkout 0.24 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone cairo from git, checkout the 1.10 branch, build it, and install it.
git clone git://anongit.freedesktop.org/cairo cd cairo git checkout 1.10 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone pango from git, checkout the 1-29-4 branch, build it, and install it.
git clone git://git.gnome.org/pango cd pango git checkout pango-1-29-4 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone babl from git, leave it on the master branch (0.1.11 at the time of this writing), build it, and install it.
git clone git://git.gnome.org/babl cd babl ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone gegl from git, leave it on the master branch (0.2.1 at the time of this writing), build it, and install it.
git clone git://git.gnome.org/gegl cd gegl ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone gtk+ from git, checkout the gtk-2-24 branch, build it, and install it.
git clone git://git.gnome.org/gtk+ cd gtk+ git checkout gtk-2-24 ./autogen.sh --prefix=$PREFIX make make install cd ..
- Clone gimp from git, leave it on the master branch (2.8.3 at the time of this writing).
git clone git://git.gnome.org/gimp cd gimp
- Edit the file
gimp-2.0.pc. With this edit, many plug-ins (like Resynthesizer) did not work.Change the line
Libs: -L${libdir} -lgimp-@GIMP_API_VERSION@ -lgimpmath-@GIMP_API_VERSION@ -lgimpconfig-@GIMP_API_VERSION@ -lgimpcolor-@GIMP_API_VERSION@ -lgimpbase-@GIMP_API_VERSION@ @RT_LIBS@
to
+Libs: -Wl,-rpath,${libdir} -L${libdir} -lgimp-@GIMP_API_VERSION@ -lgimpmath-@GIMP_API_VERSION@ -lgimpconfig-@GIMP_API_VERSION@ -lgimpcolor-@GIMP_API_VERSION@ -lgimpbase-@GIMP_API_VERSION@ @RT_LIBS@ - Build and install GIMP.
- Optionally, for the GNOME menu, create a desktop file
/usr/share/applications/gimp-2.8.desktop(or~/.local/share/applications/gimp-2.8.desktop) with the following contents.
[Desktop Entry] Version=1.0 Type=Application Name=GNU Image Manipulation Program 2.8 GenericName=Image Editor Comment=Create images and edit photographs Exec=/opt/gimp/bin/gimp-2.8 %U TryExec=/opt/gimp/bin/gimp-2.8 Icon=gimp Terminal=false Categories=Graphics;2DGraphics;RasterGraphics;GTK; StartupNotify=true MimeType=application/postscript;application/pdf;image/bmp;image/g3fax;image/gif;image/x-fits;image/pcx;image/x-portable-anymap;image/x-portable-bitmap;image/x-portable-graymap;image/x-portable-pixmap;image/x-psd;image/x-sgi;image/x-tga;image/x-xbitmap;image/x-xwindowdump;image/x-xcf;image/x-compressed-xcf;image/tiff;image/jpeg;image/x-psp;image/png;image/x-icon;image/x-xpixmap;image/svg+xml;image/x-wmf;
