I need CWirc packaged
CWirc was available in Trusty but is not available in Xenial.
Could somebody package it?
https://packages.ubuntu.com/search?keywords=cwirc&searchon=names&suite=
all§ion=all
What would you charge?
You can probably use the .deb package http://myspace.voo.be/pcoupard/cwirc/debian/cwirc_2.0.0-0_i386.deb.
You could also build it from source, https://directory.fsf.org/wiki/CWirc here is a link to the tar file.
If you need any further help let me know, I'd be happy to help.
I already tried the deb.
And I'm guessing it didn't work because you were missing dependencies?
It wants xchat and xchat-common, which as discussed aren't in
Xenial/Flidas.
You can try to grab deb files for xchat and xchat-common, and any
dependencies of those, etc. One of two things will happen:
- eventually all dependencies are satisfied
- you hit a dead end where a Trusty package is compiled against a
different version of some library than the one in Xenial, at which
point you need to build these things from source or have them
repackaged for Xenial/Flidas
However, since cwirc seems intended for use with xchat, and since you
have not asked anyone to package xchat for you, just cwirc, I wonder if
perhaps you plan to use cwirc with hexchat? If this is correct, the
proper solution is to repackage cwirc to depend on hexchat and
hexchat-common instead.
XChat is actually absent from Trisquel 8's repository. I do not know why.
I think it doesn't come in the Ubuntu 16.04 repos. I also found that it has not being maintained since 2010, I think that would be enough reason to not include it.
Yes, Xchat is dead. Long live the fork HexChat.
This plug-in is also dead, not having had any updates in 13 years. I couldn't even get it to compile due to what seems like bitrot.
It's not in Trisquel 8 because it's not and Xenial, but what's weird is
that it's back in Bionic.
https://packages.ubuntu.com/bionic/xchat
If it was removed from Xenial because it's abandoned, I'm not sure why
it's back for Bionic despite there being no new release.
https://blog.tingping.se/2018/03/02/when-distros-get-it-wrong.html
So yes; it's still not maintained. It's got security bugs that are not fixed. Move on to HexChat.
Inferior and not recomened is that a serious rumbling or disappointment,, is it gpl or variant to it that matches., gpl code...
