Installing GNOME 3.12?
Is there any way to install GNOME 3.12 in Trisquel 6...?
(Perhaps, even, all of the GNOME applications- Epiphany, Maps, etcetera?)
Sorry for the imbecile question- I'm a GNU/Linux newbie...
(Or, perhaps, 3.14...?)
Sorry for the double-post!
I think the best way is to upgrade to Trisquel 7 (once it's ready, or if you are brave enough) and add a PPA (GNOME testing/staging PPA, etc.).
Using PPA is risky because it may contain proprietary sotware and unstable software. If you want to use it anyway, I strongly recommend you to install also the "ppa-purge" tool.
This is how I installed Gnome 3.12.2 on Trisquel 7 20140807 testing version. It have not been running for over one month. If this will work at Trisquel 6.0.1 I do not know. Try?
sudo add-apt-repository ppa:gnome3-team/gnome3-staging
sudo apt-get install gnome-session gnome-shell
sudo apt-get update && sudo apt-get dist-upgrade
Source of my test
https://trisquel.info/en/forum/cannot-install-gnome-shell-trisquel-7-i18n-64-bit#comment-55679
Maybe interesting read about different ppas of Gnome.
https://wiki.ubuntu.com/UbuntuGNOME/Developers
I searched in Synaptic and I found Epiphany 3.12.0 and Gnome Maps 3.12.2.1. It must be in the Gnome PPA I have added. I do not know if the PPA I have added includes proprietary/binary blobs.
I've just upgraded to Trisquel 7 (Loving it so much~!) and am installing via that PPA now.
That PPA won't work with Trisquel 6, as it doesn't have any packages for 12.04.
Thanks!
In Trisquel 6?
You don't, I'm afraid (or at least I don't).
Install Trisquel 7 instead (it's already usable, or at least the packages are since I don't install from the ISO), then try Garsmith's suggestion:
I've just installed Trisquel 7 and used that PPA- thanks!
If you want the latest GNOME, your best bet is probably Parabola. Do keep in mind, though, that Parabola is a very bleeding-edge distro, and it's said that the bleeding-edge is soaked with the blood of its users, or something like that.
