Is it possible to install Unity Shell in Trisquel?
3 replies [Last post]
systemovich
I rather like Unity.
Both unity and unity-2d are packages in the Trisquel repositories. You can easily install them with your favourite interface to APT (e.g., the Synaptic package manager).
systemovich
Thanks Magic Banana.
I installed unity from Synaptic. I expected the login screen to show an option for a Unity session, but there was not, even after restarting.
At one point, I chose User-defined Session, ut I only got the desktop background with no panels. I did a hard reset.
When I enter the unity command at the command line, I get fata compiz errors like:
Compiz (opengl) - Fatal: GLX_EXT_texture_from_pixmap is missing
Is your system really able of 3D acceleration with free software? It looks like it is not. You should consider unity-2d instead. It relies on Metacity instead of Compiz.
