LAMP stack on Trisquel
I've heard of setting up a LAMP stack (Linux, Apache, MySQL, PHP) to run a web server on Ubuntu. I'm just double-checking, but it would seem to be exactly the same process on Trisquel, right?
name at domain, Ven 13 Mai 2016 01:46:36 CEST:
Of course you can get such a server in Trisquel, though it's
called GLAMP instead of LAMP, because of naming the system GNU/Linux
rather than just Linux.
About being exactly the same as in Ubuntu, well, I don't know.
But it's an easy process. Text-mode Trisquel 7 installer allows you
to get the GLAMP server with a single keystroke, and I think it's
similarly easy with the graphic installer. Here you have a snapshot:
https://trisquel.info/files/Encrypted_Install_26.png
That snapshot is from the Trisquel Documentation, actually from
the Full Disk Encryption Install page (
https://trisquel.info/en/wiki/full-disk-encryption-install ) but you
don't need to make an encryption install if you don't want to. The
GLAMP installation will be available to you in any case.
This message was sent using IMP, the Internet Messaging Program.
Execute, in a terminal:
$ sudo tasksel
Choose "GLAMP Web server".
Thank you, thats very usefull ;-)
Of course, you can also use a different web server, database, etc.
You can also use LXD, Docker, Vagrant, virtual machines, and the like. Does anyone have a preferred container method they use routinely on Trisquel?
