Laptop shuts down after waking up from suspend
Hello,
I currently have a Libreboot T400 running Trisquel 7.0 Belenos, with the GNOME desktop environment. Starting just yesterday, I noticed that whenever I suspend my system, the laptop restarts after I try to wake it up. I've made sure that all of my packages are updated, and it wasn't doing that before, so I'm not sure why it started doing all of this so recently. Thank you guys for your help!
Hi there! This is just a hunch (reminds me of something I experienced) but what is your output ofgsettings get org.gnome.settings-daemon.plugins.power use-time-for-policy
*******@user1:~$ gsettings get org.gnome.settings-daemon.plugins.power use-time-for-policy
true
*******@user1:~$
Ok, let's try toggling that.gsettings set org.gnome.settings-daemon.plugins.power use-time-for-policy false
I did that, and after I hit space bar it briefly came back on, then it just shut off.
Oh well... I guess you could check out which packages got updated lately in /var/log/dpkg.log
What exactly am I supposed to be looking for in those logs?
The names of the packages installed between when it worked and when it didn't.
And if the kernel was updated, then it is worth booting the previous kernel to see if the problem still occurs. To boot the previous kernel, GRUB's password (in /etc/grub.d/01_PASSWORD) must be known or removed.
Hmm, I briefly researched this and it appears to be mostly related to nvidia GPUs. That is not your case though as you have an integrated Intel one. I would try to contact the libreboot guys.
Also, first of all try upgrading to the latest jxself's kernel -> https://jxself.org/linux-libre/
