"Liberated" Adobe Flash channels
Free alternatives to Adobe Flash provide a way to view video and audio, but they still require proprietary JavaScript and they use more resources than viewing the stream in a media player such as MPlayer. I thought it would be a good idea to "liberate" (live) Flash media streams that can be accessed using Gnash or Lightspark but can work without them if a direct link is provided. Finding the direct link can be done using Wireshark.
Anyway, here is such an example:
San Francisco Bay Area's own KDFC, classical radio:
Link that can be viewed using Gnash:
http://www.kdfc.com/
http://www.kdfc.com/pages/15744854.php
Direct link to the live AAC audio that can be viewed using Mplayer (and downloaded using wget - to stop recording use control key + C):
http://9523.live.streamtheworld.com/KDFCFMAAC
Feel free to post any other links you find that work with Gnash or Lightspark (even if you cannot find the direct video or audio link).
Note that there exists an online database of links that work with VLC and MPlayer here:
http://database.freetuxtv.net/
(The free software player FreetuxTV can play these live streams.)
The KDFC channel is now available there.
That is great. ;) For European radio stations I would suggest: http://www.listenlive.eu/
all these can be configured with "radiotray" package from the repository. I find it very useful because there is the category for classical music, and Bratislava, Helsinki and Prague classical radios use .ogg streaming.
I would like to see more radio streams support Opus for its quality and open nature. Absolute Radio has Opus streams which sounds better than Ogg Vorbis: http://www.absoluteradio.co.uk/listen/labs.html#opus
Trisquel 6.0 users can nab the latest VLC and the libopus codec from https://launchpad.net/~n-muench/+archive/vlc2
