Libre Office spell check not working
Hello,
I recentley upgraded my main Trisqel machine to new hardware.
I discovered that with Trisquel 5.5, the spell check for Libre Office is no longer working. I tested this using words I knew were mis-spelled. A full check of the document claimed there were no errors.
Libre Office version: 3.4.4
Main Dictionary: en-US (I use secondary technical dictionaries as well)
Any Suggestions?
Thanks in advance.
Yours,
S
Well, the facility seems to be working for me. If you type in lskebjljbse does it flag that as a bad word? What words do you have the problem with?
Make sure myspell-dictionary is an installed package on your computer. Someone in the IRC chat channel just had this problem and it fixed it for them.
SirGrant:
That fixed it. Thanks.
Lembas:
The only reason I discovered it at all is because I didn't think I was spelling certain words correctly, yet they weren't getting tagged. I then tried deliberate misspellings like "ggood" to test it and they weren't caught either.
Thank you both for your posts.
