Libreboot on R400 no network connection possible
Hi,
I flashed a Thinkpad R400 successfully with libreboot 20160907. Everything is fine, I see the Grub Screen at the beginning and a "Ubuntu" starts from Stick or the encrypted HDD (I want to migrate to Trisquel later).
When the system is ready and I plug in the network cable or try to connect with wifi the notebooks tries endless to connect.
If I am entering a wrong pw fpr the wifi there comes an error, so the system must be connected to the router.
I also checked the Mac Address and it is the one that I put into the flash image. The Network cards are also ready so what can it bee or what can I do to look where the problem is located?
Other Laptops can Connect with the wifi and the cable, also it is an Atheros Card and the error comes also when I am booting a life System from CD.
Greetings
cyrax
