The lights of the Ethernet port does not blink and connect to internet
Hi.
My X200 recently does not connect to internet with Ethernet. I noticed that the lights of the Ethernet port that blinked while the Ethernet cable was connected does not blink. Would it be a hardware problem? Would someone know how to fix this? I use the same LAN cable with another laptop and it works. I changed the kernel of the X200, and did 'NetworkManager restart', reboot, but it did not solve the problem. Please help.
name at domain writes:
> Hi.
Do you have a docking bay for the X200? Those have an integrated
ethernet connector that you can test with.
"Cut your own wood and it will warm you twice"
No I have not it. I want one.
It was solved. Sorry for the fuss. I cannot explain it in English but it was my misunderstanding :p
The both lights are sparkling energetically now.
As if my shack is a nightclub.
