login screen Inaccessibility in Trisquel 7.0, using included Orca 3.6.1
1 reply [Last post]
alimiracle
hi all
login screen Inaccessibility in Trisquel 6.1
Dave_Hunt
I'm confused-- are you using Trisquel 6.1 or 7.0? I have an instance of 6.0.1 with an accessible login greeter; the instances of 7.0 I'm testing do not have accessibility in the login screen. Trisquel 7.0, dated 14, June has orca 3.12.1, I think it is. Since I am the only user of the Trisquel 7 instances, I have set myself up as the automaticly-logged-in user. Other GNU/Linux distributors have trouble with getting accessibility on lightdm (the greeter). IGDM 3.12 accessibility may work; it can be toggled with the 'alt+super+s' keystroke.
