Need help in customization
Hello,
I has been trying to customize colors, size of windows and icons. Searching on internet i installed compizconfig setting manager,color chooser, deconf-tools. deconf-editor is very difficult due to so many option.
I want to reduce size of bottom panel, reduce size of icons in panel, reduce size of nautilus window title bar. change background color & opacity of nautilus windows.
i have changed color of borders & title bars using color chooser. But, it looks not good.
Need help for correct method to do.
Alt + right click panel -> properties -> size
changes size of panel to 28 & orientation to top. panel icons auto changed sizes. Thank-you Lembas.
Changed background of nautilus using deconf after following steps on internet.
So, only remains size of title bar on the nautilus windows & if possible opacity of nautilus background.
Since Trisquel 5.5, the default window manager is Mutter and not Compiz. If you have not changed it, configuring Compiz is useless.
Trisquel 5.5 uses GNOME's fallback mode by default, which uses Metacity as a window manager. Mutter isn't even installed by default.
