pglgui icon not showing in system tray
Hello all, I've installed pgl on my linux, but can't get the icon to display in systemtray when running pglgui. Any ideas how to get this working? Its always automatically worked with other distros, not sure what I have to config to get it working on the Trisquel Gnome edition.
Thanks,
Rich.
What a coincidence, we have been talking about that in code.trisquel recently.
What it is happening is that there are no "tray" but an "indicator applet" instead. Initially, the tray was alongside the indicator applet but it was later remove because there was some bug in the panel. now the problem seems solved and we are discussing to bring it back (see merge request #110).
To add the tray to the applet: "alt" + "righ click" on the panel and select to add applets. Then choose the "notification area", and be sure it is on the panel. It is initially empty so try to start the program and see if it is there, if not, be sure you put the applet correctly.
I hope it helped.
You're the best!
haha i screwed up my panel, for some reason, i just had to uncheck expand to see what it did, lol, then when checking it back, it screwed up the spacing and some icons on the system tray side. I even deleted the panel and made a new one from scratch and it had the same issues.
FOr example, The weather in the clock applet now takes a while to show up and has an empty space at first where the weather should be shown, and there is some extra spacing between the some of the applets....
Also another weird note, if I left click the clock as soon as desktop is loaded, it will send me instantly back to the login screen.
But, the small pgl icon, is now centered in the panel instead of alligned with the top, so i can still have the same large panel with for double layered windows tabs, and have the pgl icon in the center. which is actually what I was trying to do, not even knowing it would be fixed that way. So the fact the weather part of the clock does eventually appear, means I can live with this. no big deal, it doesn't look bad at all. I'm just giving some info.
tks again slacker u da man!
