Plasma cannot start. All shell packages missing.
19 replies [Last post]
amuza
Hello,
I have installed Triskel, this is my first time with KDE. On the top of it I installed i3 windows manager and Guix package manager. I configured konsole to have white letters on the top of a black background. I also installed some other programs. Today I have opened Konsole and it was different: the background was white.
Then I wanted to log into KDE (I am normally using i3) and I could not make it. Right after entering my password I see nothing but this message:
"Plasma cannot start. All shell packages missing. This is an installation issue, please contact your distribution".
I can press Ctrl+Alt+2 and get a terminal, but I do not know how to fix it.
How can I restore Plasma?
Thank you
amuza
Just in case this information could help:
When using Konsole within i3, it's not only that my configured colors are gone, but also the arrow keys of my keyboard are not recognized.
amuza
Could it have something to do with the fact that I played with this?
konsole > Settings > Configure Konsole > Profiles
I think it was here where I changed the color settings and made it the default profile.
amuza
I tried to fix it with this:
sudo apt install kde-plasma-desktop
sudo apt install triskel
sudo apt install triskel-recommended
sudo apt install triskel-settings-desktop
sudo apt purge konsole
sudo apt install konsole
But it made no difference I still cannot login to Plasma. I keep getting this message:
Fortunately i3 is still accessible.
As I cannot manage to restore Plasma, I am considering to get rid of it.
If I uninstall Plasma, will I still be able to access i3?
Is it safe to to remove Plasma and install Mate?
Should I first install Mate and then remove Plasma?
lanun
Did you try to log in right after installing Triskel?
amuza
Hey, thank you.
I think I did:
and then I tried. With no success.
By the way, now I installed Caja because Dolphin does not show icons. But caja does not open. If try to launch caja from Konsole, I get the following:
(caja:2626): GLib-GIO-ERROR **: 16:52:21.639: No GSettings schemas are installed on the system
nadebula.1984
There is one thing I need to know: whether KDE desktop environment could coexist with i3 window manager.
When you install i3 window manager, does it say that it also removes KDE's window manager?
lanun
I think this might be of interest to you: https://www.ryanlue.com/posts/2019-06-13-kde-i3.
amuza
Nope, it says nothing. I installed i3 on KDE and everything looked fine. I thought everything would work ok as it does when you install i3 on Mate.
You install i3 and, without doing anything else, next time you login, at the screen where you enter username and password, you will be able to choose between your original Dektop Environment or i3. That is my experience with Mate and KDE.
lanun
Can you login if you install from a live session, using the graphical installer?
amuza
I can login from i3 and access every file.
What do you mean by install from a live session?
Do you mean to reinstall the system?
Maybe you mean to live boot and connect my profile from there.
I would not know how to do that.
lanun
Yes, but directly from the Triskel iso instead of the netinstall.
amuza
I get this error for every program I try to install (I mean from i3, I cannot login to Plasma).
I give up, I am going to reinstall everything and go back to Mate + i3.
Thank you for your help!
amuza
Just wanted to add that I went back to Mate + i3 and had the same problem, I could not login. I had to reinstall everything once more.
The cause of the recurring problem was the Guix package manager.
Maybe it was something easy to fix, but I did not now how to do it, and I had these words of Magic Banana constantly visiting my head, they were about Guix' stability and also about not being very user-friendly.
I decided to stop using Guix and life became easy again!
lanun
This most certainly was about using Guix as a standalone OS. As a package manager on top of Trisquel, Guix is a breeze.
Why did you decide to use it in the first place, may I ask?
amuza
Yes, you are right.
For some time it was for me too, I loved it.
In the first place because I wanted to try its containers, other containers I know require you to trust binaries, and they are not signed by any trustuble source. I never had the time to get into this container thing, but in the meantime I was enjoying very much other Guix advantages, like having latest-version apps in Trisquel.
I must also say I found Guix does not protect users as much as Trisquel does. With Guix you can install software that allows you to install non-libre software without any warning. I hope that changes eventually.
lanun
Are you sure about that? I would have thought that Guix System being recommended by the FSF as an OS, the Guix package manager around which it is built would also be protecting software freedom. If you think it is not the case, you might want to report to the FSF.
Citing what I have just written in https://trisquel.info/forum/trisquel-devuan-unstable-i-did-thing#comment-158880:
The presence of Pip among the packages (and maybe other such packages easing the search and installation of possible nonfree software) may be the reason for the claim: https://guix.gnu.org/packages/python-pip-20.2.4/
lanun
Just noticed that the 'pypibrowser' and the 'pipsi' packages are currently in the Trisquel repo. Are they possibly creating a similar situation to the python-pip package being in the Guix repo?
I think so. Would you create a new issue? Here is the link: https://trisquel.info/node/add/project-issue/trisquel
