problem with opengl
Hello, I have a problem with opengl that crashed Kwin used by the KDE desktop.
It is a driver bug so I ask for your help to tell me how to find and update the driver.
Thanks.
You can use this repository to easily install the latest Linux-libre kernel (hence the latest drivers).
In case the driver update won't help:
I had a problem with Kwin crashing from time to time. Here is my original post. If you scroll down, you'll find the work-around that helped me solve the issue.
The driver update isn't a bad thing, but if you have the same problem as I did, it probably will not help much.
