Problem with Trisquel 4.5.1
I downloaded the latest 4.5.1 release iso of trisquel yesterday. I can boot the iso image in virtualbox just fine, but when I tried to boot the cd on bare hardware, I got the following error message. "stdin error init 5 /dev/sdc not found". What I surmise is init had a bug and rendered the system unable to load from the cdrom. I noticed this only after waiting and watching the boot splash screen for over 5 minutes with the flashing trisquel logo. I then pressed the escape button and found the above error message.
While in virtualbox, I booted the system and selected "check disk for errors" to check the iso file, and it checked fine! My hardware is 3-4 years old, and perhaps without the "blobs" the kernel could not initialize certain hardware? I don't know, but I really want to use trisquel because I am convinced that non-free software is a trap, and I don't want to be trapped by the "convenience factor"!
Thanks!
I've tried searching for that error message, and it doesn't seem to be a common problem, so maybe it is Trisquel-specific?
If you have a flash drive, could you try booting from that instead?
I do not have a flash drive that has the capacity enough for the OS. I had one a few years ago, a 8 gig drive, but alas it is missing!
Try using the install options, not the "Try Trisqule" one. Try
installing with the NetInstall edition, either from USB or CD.
Shouldn't /dev/sdc be a harddrive? Maybe you should do chkdsk while in Windows and check for errors on it. Or maybe the hard drive was partitioned in some weird way that causes problems?
I once had an error message with Trisquel booting from a live-cd. It basically said, that the harddrive wasn't closed properly or something like that, I assume it was because of the non-standard shutdown Windows had before.
Yes, the NetInstall is only 12 MB! Fits on probably any flash drive you have :)
I suppose the NetInstall would have fit, but I did not want to install just yet. I wanted to test trisquel out beforehand to see if all the hardware is detected properly. I booted the live-cd on my HP laptop and had no problems, except the wireless did not work! I bet it is a lack of some "Blobs"! I will have to buy a usb wireless stick that works with Linux-Libre!
We really need to raise some money and hire people to reverse engineer the proprietary bits and replace them for Linux-Libre. That is one reason I am a FSF associate member.
