Settings after Trisquel 8 installation
Hello! I use Trisqule + LXDE + Lightdm on Laptop 1.9 MHz, 8GB Ram. After installation I turn environment like this. I delete unnecessary packages, install necessary packages, disable NetworkManager and create wpa-supplicant unit for systemd, also configure iptables, tor, icecat. numlockx for auto switch on numlock after boot.
# Install and delete packages
2 apt-get install apt-file icecat gimp audacious audacity abrowser thunar geany tor iptables openvpn filezilla evince pdftk libreoffice git numlockx
4 apt-get remove sylpheed pidgin xfburn xsane xscreensaver
# Remove unnecessary units from systemd
# Networkmanager save wifi password so I do not use it
5 systemctl disable NetworkManager
# acpid reacts on events listening own file. systemd does this. so I disable acpid
systemctl disable acpid
systemctl disable acpid.path
systemctl disable acpid.socket
# if have no printers disable cups - print service
252 systemctl disable cups
# friendly recovery mode - what's this?
256 systemctl disable friendly-recovery.service
# if you would like to turn clock manually without system connects to time server disable time synchronization
260 systemctl disable systemd-timesyncd.service
261 systemctl status ureadahead.service
# not having LAN disable remote-fs and avahi
265 systemctl disable remote-fs.target
334 systemctl disable avahi-daemon.service
Internet through wpa_supplicant
# cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
ssid="homewifi"
scan_ssid=1
proto=WPA2
key_mgmt=WPA-PSK
psk=hashmyhash
# ifconfig wlp2s0 up
# wpa_supplicant -B -i wlp2s0 -c /etc/wpa_supplicant/wpa_supplicant.conf
# dhclient wlp2s0 &
# ping fsf.org
..it goes ok..
# cat wpa2.service
[Unit]
Description=WPA 2
Wants=network.target
After=sys-subsystem-net-devices-wlp2s0.device
Before=network.target
BindsTo=sys-subsystem-net-devices-wlp2s0.device
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/sbin/ifconfig wlp2s0 up
ExecStart=/sbin/wpa_supplicant -B -i wlp2s0 -c /etc/wpa_supplicant/wpa_supplicant.conf
ExecStart=/sbin/dhclient wlp2s0
[Install]
WantedBy=multi-user.target
# systemctl enable wpa2.service
Iptables configuration
nano /etc/iptables-desktop.config
cat /etc/iptables-desktop.config
*filter
:INPUT DROP [0:0]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [0:0]
-A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
-A INPUT -m state ! --state NEW -j DROP
-A INPUT -i lo -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 8 -j ACCEPT
COMMIT
iptables-restore < /etc/iptables-desktop.config
service iptables save
# installing iptables-persitant for run firewall configurations with systemd after boot
apt-get install iptables-persistant
Why go this route, ass-backwards? I mean "install and then remove."
Use netinstall ISO image, install the basic minimum CLI interface and only add software you need.
Currently, if the user selects "recovery mode" from the bootloader menu they end up dropped at a root shell prompt. Ideally, they'd end up at a small ncurses application, one option of which would be "root shell".
Other options can include things like "start system in safe graphics mode" or "forgotten password recovery".
https://blueprints.launchpad.net/ubuntu/+spec/friendly-recovery
This is intriguing.
What is your reasoning for preferring wpa-supplicant over networkmanager? Is it more secure, or a better connection somehow?
And could you talk about what you are accomplishing with that Iptables configuration? Is this primarily for security, or for network speed, or both?
NetworkManager does not connect it only controls interfaces using wpa_supplicant for low-level functions. I do not need this buffer so I use only wpa_supplicant. The main reason is that NM saves password as it is. wpa config contains password hash. wpa_supplicant without NM is more secure.
Iptables is that buffer between user and kernel module named Netfilter that gets user commands and relies it to netfilter rules. Just this. I do not use any gui firewall cause I do not think there is any good soft, and "firewalld", "ufw" do not have anything more I need. In Linux there are only command line features like iptables, nmap, netstat for controlling and monitoring network.
My iptables rules for desktop allow any outgoing traffic (`output accept`), decline all forwardings (`forward drop`), cause my pc is not a router, disallow incoming traffic (`input drop`) except established and related connections. As I understand only web-sites that I am requesting may send me answer connecting to open ports. Also ftp, I think.
Also it allows any ethernet connections (but I do not use ethernet, only wifi).
ICMP , I'm not sure I need it, just copied as it was in the example.
