Triskel 9 updater?
3 replies [Last post]
amtrakuk
How does Triskel 9 keep up to date? I can't find an update manager like LXDE or MATE.
lutes
On Trisquel 9, using the default MATE environment, you can find both "Software & updates" and "Update manager" in System > Control center > Administration.
They are in the "Accessories" menu category but they are not selected to appear in the Application menu by default. You can change this in System > Preferences > Look and feel > Main menu (or in Control center > Look and feel > Main menu).
EDIT: sorry I misread the very first word of the title of your post. I never used KDE but its package, software and update managers seem to be muon, muon-installer and muon-notifier respectively.
amtrakuk
Thanks. I'll give the muon suit a go. Seems odd no update handler appears to be installed/running
arielenter
amtrkuk would you kindly check if you are having The following issue too?
https://trisquel.info/en/issues/27374
I asked on the forum but nobody seemed to be using kde, and I started to use mate instead because of that problem.
