Trisquel 7 RC: Monitor spec sensing issue?
Anyone else seeing a problem with Trisquel 7 determining the proper
resolution of monitors?
I've got an LG W3000H that can do 2560x1600 but Trisquel 7 shows me
1920x1440. As a result everything is large and wider than it should be.
I have the same problem but unfortunately no solution. Sorry, pal. :-(
Do you have an AMD graphics card?
There might be one in that computer, I'll have to take a look next time
I'm using that system. I recall that the graphics section of the
"Details" settings panel says the "VESA: RV730" driver is being used.
I'm guessing that you ask about AMD graphics cards because AMD graphics
cards need some nonfree software to fully recognize a monitor's
resolution above a certain screen size?
If so, any recommendations on what graphics card to use instead?
Thanks.
Intel or older (3yrs+-) nVidia GPU.
Yes, according to the vendor info; here's the output from lshw for the
graphics card:
product: RV730 XT [Radeon HD 4670] [1002:9490]
vendor: Advanced Micro Devices, Inc. [AMD/ATI] [1002]
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities:
vga_controller,
bus mastering,
PCI capabilities listing
configuration:
latency: 0
resources:
memory: c0000000-cfffffff
memory: fea20000-fea2ffff
ioport: e000(size=256)
memory: fea00000-fea1ffff
