TWM and the missing "menu"
Hello. I'm trying to use TWM but find the "menu" item in the repos is missing. Hence no application menu when using TWM.
Any ideas how to remedy this?
And by the way I'm using Trisquel 7.
I run Trisquel 7 with all repos enabled (main, updates, security, backports)
and use twm. On installation, menu was listed in the recommended packages, and
so I installed it. apt-get found menu fine. It works.
By 'not being able to find it in the repo' do you mean *you* couldn't find it
in the online package list browser? Do you mean apt-get didn't find the
package? Do you mean that an apt search came up blank? Details, please.
It would also be useful if you were to post the contents of your apt sources
list and config files.
