Unable to update system
7 replies [Last post]
dragospirvu75
Hello. For the last 2 weeks, whenever I run sudo apt update, I get this:
Ign:1 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo InRelease
Ign:2 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo-security InRelease
Ign:3 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo-updates InRelease
Hit:4 https://updates.signal.org/desktop/apt xenial InRelease
Err:1 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo InRelease
Could not connect to quantum-mirror.hu:443 (127.0.0.1). - connect (111: Connection refused)
Err:2 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo-security InRelease
Unable to connect to quantum-mirror.hu:https:
Err:3 https://quantum-mirror.hu/mirrors/pub/trisquel/packages aramo-updates InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
W: Failed to fetch https://quantum-mirror.hu/mirrors/pub/trisquel/packages/dists/aramo/InRelease Could not connect to quantum-mirror.hu:443 (127.0.0.1). - connect (111: Connection refused)
W: Failed to fetch https://quantum-mirror.hu/mirrors/pub/trisquel/packages/dists/aramo-security/InRelease Unable to connect to quantum-mirror.hu:https:
W: Failed to fetch https://quantum-mirror.hu/mirrors/pub/trisquel/packages/dists/aramo-updates/InRelease Unable to connect to quantum-mirror.hu:https:
W: Some index files failed to download. They have been ignored, or old ones used instead.
It worked before, I didn't make any user/update/permission changes. How to solve it? Thank you.
Open.Trisquel
https://status.artixlinux.org/mirrors/quantum-mirror.hu/
your mirror appears to be down according to the mirror status checker on artix
it could be an issue along the route or at the webserver itself.
Solution: use different mirrors
comment out the old mirrors and pick new ones in /etc/apt/sources.list then sudo apt update to apply the changes, these are the defaults for aramo
# Trisquel repositories for supported software and updates
deb https://archive.trisquel.org/trisquel/ aramo main
#deb-src https://archive.trisquel.org/trisquel/ aramo main
deb https://archive.trisquel.org/trisquel/ aramo-security main
#deb-src https://archive.trisquel.org/trisquel/ aramo-security main
deb https://archive.trisquel.org/trisquel/ aramo-updates main
#deb-src https://archive.trisquel.org/trisquel/ aramo-updates main
deb https://archive.trisquel.org/trisquel/ aramo-backports main
#deb-src https://archive.trisquel.org/trisquel/ aramo-backports main
dragospirvu75
It worked as expected, thank you my friend.
Gottfried
the quantum-mirror.hu didn´t work for me either since 4 weeks approximately.
I am going to change the mirror.
thanks Open.Trisquel for posting them.
Gottfried
which mirror would you suggest or is stable ?
especially if you live in France, Germany, Austria, Switzerland ?
In the first tab of the "Software & Updates" utility, where you can set where to "Download from", if you choose "Other...", you can click on the "Select Best Server" button. It will perform a series of tests and pick for you the most appropriate server.
Gottfried
doing so it gave me:
a mirror of Sweden:
https://ftp.sunet.se/mirror/trisquel/packages
Ark74
Sounds about right.
