Update issue
When I run some apt command, I have a message that ayatana-settings, group-service, libgroup-service1 and mate-user-admin are unnecessary and I should run sudo apt autoremove to remove them. If I do so, later one, the GUI for software updates tells me there are 4 packages to install and if I say ok, it re-installs them.
Besides, "sudo apt upgrade" says the package trisque is not updated. It is the same if I try dist-upgrade, full-upgrade or with aptitude.
Not sure what to do.
No explanation is given? Maybe broken packages? The Synaptic Package Manager has a Custom Filter (one of the buttons in the lower-left corner of the window; then seek "Broken" above them) to list them.
Synaptic says no package is broken.
No information why on the previous commands.
I just tried "sudo aptitude dist-upgrade", this is different:
used@imac:~$ LC_ALL=C sudo aptitude dist-upgrade
The following NEW packages will be installed:
ayatana-settings{a} group-service{a} libgroup-service1{a} mate-user-admin{a}
The following packages will be REMOVED:
gnome-system-tools{a} liboobs-1-5{u} system-tools-backends{u}
The following packages will be upgraded:
trisquel
1 packages upgraded, 4 newly installed, 3 to remove and 0 not upgraded.
Need to get 2068 B/1014 kB of archives. After unpacking 8084 kB will be freed.
Do you want to continue? [Y/n/?]
Does it look ok to say yes?
I had this, said yes, and it was fine. It seems that the others (like apt, etc.) are unable to handle this situation.
I am confused. Or, maybe, Avron was confused when he wrote that the software updater "re-installs" the four packages that 'apt autoremove' removed. Such an infinite loop has actually never existed?
Maybe a new install using the oficial (old) iso set.
