Window Border Themes
Having just moved from V6 to V7, I'm a little disappointed at the lack of window border themes since those I just copied into a .themes directory in V6 no longer work using this method. Is there an easy way to add to the limited options provided as standard?
search for themes in synaptic, it will at least give ou some options.
What about doing a "sudo nautilus" from the terminal and copying the theme to /usr/share/themes instead?
Don't use `sudo nautilus`, use `gksudo nautilus`, which sets environment variables and such properly.
