11. Wifi driver failed - Broadcom (14e4:43ba)
Hi,
I installed 2 libraries in my TRISQUEL machine and the built-in wifi
got recognised and worked on the spot.
(tried to attach them here but it was rejected -too big):
1) b43-fwcutter_019-2_i386.deb
2) firmware-b43-installer_019-2_all.deb (part of a large zip file with
many versions of the wifi adapters).
Send me a mail and I will send you the files ;-)
Otherwise, just order an external wifi dongle from ThinkPinguin.com
(https://www.thinkpenguin.com/gnu-linux/penguin-wireless-n-usb-adapter)
A bit expensive but works like a charm out of the box in Trisquel !
Brgds,
Yvo.
*IT beheer met raad en daad ...*
Gasthuisstraat 25,
3200 Aarschot
Gsm: +32/(0)475/53.92.86
Tel.: +32/(0)16/57.05.40
Skype ID: yvo.brasseur
(Pls send SMS or mail before using Skype to have it activated.)
That firmware is not free as in freedom. Neither is Skype.
Our community's resources --the forum, documentation, etc-- are for free software only. Please do not distribute, recommend, or support non-free software here.
https://trisquel.info/en/wiki/trisquel-community-guidelines
If possible, replace the built-in Broadcom card with an Atheros ath5k/9k (but not Qualcomm Atheros ath10k), then you no longer need to load non-free firmware.
If not possible (probably because of "white-list" restrictions of the firmware), then purchase one ath9k_htc USB WLAN adapter. It still requires firmware to be loaded, but there are free firmware packages from Trisquel's or Debian's main repository.
For communications, Pidgin is highly recommended.
