Abrowser lag in Trisquel 5.5 when using fallback session
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I recently installed Trisquel 5.5 on a system with this partition scheme:
/ on /dev/sda1 (SSD / solid state disk)
SWAP (9GB) and /home (~1TB) on /dev/sdb1 and /dev/sdb2 respectively
(SATA 7200 RPM disk)
I am using home directory encryption.
When using Gnome "classic" (fallback), Abrowser lags terribly and I
experience pauses / freezes when scrolling.
Gnome panel works well without noticing such problems.
The browser profile is on the SATA 7200 RPM disk, its cache is running
from /tmp which itself is mounted in RAM.
What could be causing this? The chipset is i5 680 (sandy bridge),
Intel drivers are loaded correctly - and this works well in Trisquel 5.0.
I'd appreciate any hints on resolving this, I prefer to use the
fallback mode.
Cheers,
Fabian
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: PGP/Mime available upon request
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/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=qoBn
-----END PGP SIGNATURE-----
Heard exact the same from a friend who uses encryption. After an update to 5.5 Abrowser tends to just close itself, so does the filemanager.
I'm leaning towards the encryption being the problem.
